Old 07-31-2004   #1
Kougar
Drives: 06 RSX
ok, on my 4th time of putting tranny up, i installed a new master and slave cylinder too. I also went with the old TO bearing since the new one is like 1/8" bigger.
Now the pedal sticks. Basically, it shoots down by itself after a small push about 2/3 the way, then the last 1/3 is normal resistance. Once you let it come back up the 1/3 that it does itself, you have to pull it up the rest of the way. It was bled for about 30 minutes. I even disconnected the pedal to the master and pushed on the actual piston to get a better bleed. It pushed out WAY more fluid, but didn't really help at all.
So now what?
