Old 08-12-2004   #1
Khadgar
Can't Actually Wrench
Can anyone help me tune?
I have a dsmlink/wideband commander setup and well I'm having issues getting it running nice.
I am also having trouble increasing my boost, I turn up my boost controller but the boost doesnt go up, it sounds like a have a leak but I didnt hear one with my boost leak tester.
Old 08-12-2004   #2
Is your MBC hooked up right? If it is try a different one, maybe the spring is stuck inside.
CRAIG
Old 08-12-2004   #3
Khadgar
Its the hiss that makes me wonder, its /quite/ loud.
Old 08-12-2004   #4
Khadgar
BISS screw :rant:
Old 08-13-2004   #5
Kougar
Drives: 06 RSX
...Man you are one :censored: weird kid kyle :stick:
Nonetheless, :goodluck:
Old 08-13-2004   #6
jpretz
I love how Kyle is teh Anti Social-- until he needs some help with teh Talon.
Old 08-13-2004   #7
If you boost leak tested it and it was fine. Then when you put the intake back on and it hisses, I would say there is a leak before the turbo. That would explain why you can't build that much boost. Are you still running the 2G MAF? Check that out first of all if you have boost leak tested it.
CRAIG
Old 08-13-2004   #8
Khadgar
I cant hear the leak with the leak tester, but I can without it, its the BISS screw, I need to turn it all the way in to make it stop leaking, but my idle is like 400 RPM now, I have a MAFT blowthru setup so it can be premas leak.
Old 08-13-2004   #9
tsiawdspeed
tsiawdspeed's Avatar
Send a message via AIM to tsiawdspeed
They sell o-rings at Home Deopt that will fix that problem
tsiawdspeed is offline   Reply With Quote
Old 08-13-2004   #10
Khadgar
I might go try ace, that thing seems hard to get out tho (the screw)
Old 08-13-2004   #11
use a tiny tiny tiny flat head.
Old 08-13-2004   #12
Khadgar
argh I'm trying to, it just unscrews to the point where i can't wedge anything in around it.
Old 08-13-2004   #13
if the car drives bring it by.
Old 08-13-2004   #14
Kougar
Drives: 06 RSX
Drive it by huh?
So kyle.........gonna do that? :stick:
REMEMBER :naughty:
Old 08-13-2004   #15
Khadgar
It was my TB gasket, it was backwards :uh:
Old 08-13-2004   #16
So how didn't that leak when you boost leak tested it?
CRAIG
Old 08-13-2004   #17
Khadgar
I don't know, but it couldnt hear it unless teh car was on, maybe it was a big enough leak that it was silent unless there was a ton of air being sucked in, I wonder if thats why I couldnt boost very high?
Old 08-14-2004   #18
Huh, I didn't even know you could put that gasket on backwards. I thought it was just flat. If I remember correctly, the BISS is a phillips head. I believe I use a magnetic screw driver to pull them out. They unscrew and do not reach the top of the hole for them.
Old 08-14-2004   #19
Khadgar
Biss feels plastic, and its the gasket between the TB and the manifold, it has a tab on it that needs to be facing towards the front of the car, it blocks some passages for the BISS i think.
Old 08-14-2004   #20
95tsi
95tsi's Avatar
Drives: a pos
couldn't you just turn the idle set screw in all the way if it is still a problem then change your idle on dsmlink til you figure out how to fix it?
