Old 08-14-2004   #1
b00stingsx
Send a message via AIM to b00stingsx
ok i am rebuilding my engine, and have a few questions. I ordered the complete engine rebuild kit with .02 over pistons, so i need to have the block machined. I know they machine the cylinders, and they "deck" the top of it, but what else do they do. also, should i have anything else machined while i am at it?
also, my valves are all out of whack b/c they hit the pistons. Is it hard to rebuild a head? do i need special tools? would it be a better choice to take that in to a shop and have them rebuild it?
Any good machine shops in town?
b00stingsx is offline   Reply With Quote
Old 08-14-2004   #2
acidrumz
bore the block, provide the new pistons for the machinist for measurements.
resurface the block and head. milling/deck is required if yours is in bad condition.
you do need a special tool to get to the valves, you should have the machinist replace your valves and valve stem seals. also if you want, he can do the 3 angle valve job so you can have a better seal. you might also have to replace your guides too.
good luck.
later.
Old 08-15-2004   #3
Raptor
ConArtist
Raptor's Avatar
If you are curious about machine shop options and costs, we have ours listed on our website
QPR Engine Machining
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
