Old 08-23-2004   #1
illz
anyone know what size bolt threads into the port that's used as the coolant feed for the turbo? you can pull the nipple out of that hole and it's threaded, but i don't know the bolt size.
Old 08-23-2004   #2
Too bad you didn't post this the other day when I had it off the winter beater. I would guess a 10MM by 1.50.
Old 08-23-2004   #3
illz
cool, thanks, ill just grab a bunch of 9-10-11mm bolts in varying pitches. one will have to be right
Old 08-23-2004   #4
Sorry, I thought you were talking about a different line. Are you going to loop the coolant lines or block them off? It is 3/8 MPT on a 1g.
Here is what I did:
http://www.dsmstyle.com/forum/index.php?sh...=995&hl=coolant
Old 08-23-2004   #5
illz
nope. return line is already gone, i had the return T'd in up by the TB. feed comes off the tstat housing from a nipple, which i've been told if you crimp and pull out with pliers, there is threading inside to insert a bolt. I think it was 10mm x 1.25, but I got 10 x 1 10 x 1.25 and 10 x 1.5 to be sure. thanks though
