Old 08-26-2004   #1
nightstalker
Guest
Tournaments Won: 6
Posts: n/a
Ok i need some advice my g/fs gsx engine blew she rebuilt the whole motor but not it won't shift right, How many ppl think the tranny (auto) needs rebuilt.... I Say YES but she insist it doesn't. Leave me some, so i can show her. thanks
Old 08-26-2004   #2
LightningGSX
Hellbound
What do you mean it won't shift right?
-Nulli Secundus-
Old 08-26-2004   #3
nightstalker
Guest
Tournaments Won: 6
Posts: n/a
It like literally stumbles when its driving and when we stop at a red light it takes so long for us to get up in a higher speed, like u can hear the turbo spool really bad but it doesn't seem like anything is happening
Old 08-26-2004   #4
Either your end clutch is on its way out or the torque converted is on it way out.
CRAIG
Old 08-26-2004   #5
You have no problem. That is just how the Auto's are. I test drove a 97 GS-T spyder. You get on it and it goes no where. A manual has a lot more kick in it. My old integra felt faster than the Auto eclipse.
Old 08-26-2004   #6
Thats not true, yeah they are going to be doggy from the start when you just punch the gas but once the turbo spools there isn't too much difference. The shifting stiffness isn't there but the car shouldn't lack the power. You are going to experience some drivetrain loss from the auto tranny but its not going to be significant enough to make you feel like its N/A or something.
What he is describing is common with 2G autos, they are really hard on end clutchs and torque converters. The reason being is they are extremely heat sensitive and if they reach over 200 degrees too often stuff wears out fast. The only way to cure it is with a aftermarket tranny cooler and maybe some good fluid.
CRAIG
Old 08-26-2004   #7
Definatly an end clutch kit is needed or a new TC. If your in there look into a shift kit as well.
Old 08-26-2004   #8
nightstalker
Guest
Tournaments Won: 6
Posts: n/a
but this is for my g/f's 1gen 91 gsx
Old 08-26-2004   #9
Well thats even worse, they have weaker auto trannies that the 2Gs do. But still the same problems but they wear out even faster.
But you have one thing in your favor, they are cheaper to upgrade and fix.
CRAIG
Old 08-26-2004   #10
nightstalker
Guest
Tournaments Won: 6
Posts: n/a
How much do u think to fix it so i can tell her so she doesn't get ripped off
Old 08-26-2004   #11
Well that depends on whats wrong with it. If its the end clutchs, the alto end clutch kits are around 125 dollars. If its the torque converter you are looking at around 400 for a cheap one and it upwards of 750 for a good one like the precision industries ones. The 2G ones are more but they are a lot stronger, I am not sure why they don't make a triple clutch torque converter for a 1G but they don't.
Umm and then while you have it apart I would recommend you put the translab shift in it, they are only 75 dollars but are a pain the ass to put in. I am sure a local trans shop could do it. Maybe even QPR would tackle it but I don't know.
CRAIG
Talk to DSMstyle, the pissed off skinny white kid. He is good at sitting behind a computer and looking up prices.
Old 08-26-2004   #12
No i'm not.
Old 08-26-2004   #13
joem
Drives: 1991 Talon awd auto
Originally posted by DSMStyle@Aug 26 2004, 04:24 PM
No i'm not.
YES, YOU ARE.
joe
