Old 09-24-2004   #1
TSISLEEPA
Guest
Tournaments Won: 6
Posts: n/a
I finally put in my new turbo tonight! its running a little rough but nothing a
little tuning with the afc cant fix. Had a plain b 16 g on it before now i have a evo b16g just a little bit bigger. now more fun it the tsi.
Old 09-24-2004   #2
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
I'd say upgrading from a big 16g to an evo 16g was a waste of money unless the other one was bad.
7/25/09
Old 09-24-2004   #3
Enes
Enes's Avatar
don't spoil mans excitement.. how cruel are you..
LOL j/k..
should of just gone either with s20g if you want daily driven with boost..
or a 50 trim if you want higher boost less during regular driving.
-E
Old 09-24-2004   #4
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
I wuld have gone to a 20g or 50 trim if it was for upgrading purposes. You won't even notice a difference between the evo and big on the but-o-meter or much by numbers. Defenitly not enough to justify buying a new one IMO
7/25/09
Old 09-24-2004   #5
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Done it your self? And remeber you can't compare from one car to another, times/ speed varyfrom car to car with the same turbo. Just look at Peter's car for example. 16G and a high 14 at best if I remeber right.
Old 09-24-2004   #6
Emcee gsxtc
Emcee gsxtc's Avatar
Well sweet, I hope you enjoy it.
Everyone else should remember that not everyone wants 900hp and 7 sec quarter mile times. :stick:
Run your car not your mouth!
Pick Two: FAST CHEAP RELIABLE
Old 09-24-2004   #7
Enes
Enes's Avatar
sometimes.. like in my case. it also comes down to the driver as well...
-E
Old 09-24-2004   #8
The EVO III 16G is not going to produce much more power than a a regular Big 16G. However it is a definate upgrade, and is a lot better turbo. Here is why:
The EVO III 16G has a stiffer WG actuator spring, the turbine housing weighs 2lbs less, the turbine outlet is 2.5" vs. 2" on the regular Big 16G, the compressor wheel on the two turbos is quit similar, the EVO III is only .010" larger, the compressor wheel blades are 50% thinner than the Big 16G. So it doesn't take a genious to a add all that up and get a quicker spooling, more effecient turbo.
Yeah its not a huge upgrade but its definetly a step up from the Big 16G. If you don't want to make huge huge numbers and just want a quick street driven daily driver for CHEAP (turbo is only $550) than its a good choice.
The turbo will make 400 hp with supporting mods.
CRAIG
Old 09-24-2004   #9
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
I got 320 to the wheels with a weak motor(173K old) with it and a conservative 22 psi. I can't wait to see what happens when I get the built motor, sheet metal, cams and 75 shot. Plus I don't have to spend more than a few bucks a gallon to run gas to get those numbers.
Good choice, you'll like it.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 09-25-2004   #10
CRAIG
Please link me to a dyno sheet with a 400 hp 16g please. I would like to see where it spools, hp and torque. Are you talking about on the juice?
Old 09-25-2004   #11
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
That would need to be a lot of supporting mods. You don't need anything to really support a 16g.
7/25/09
Old 09-25-2004   #12
EVOIII16G DYNO CHART
There it is for all you non believers.
CRAIG
Old 09-25-2004   #13
Chart.
Old 09-25-2004   #14
Wow, that is one laggy 16G.
Old 09-25-2004   #15
Must be the .010" bigger wheel....
CRAIG
Old 09-25-2004   #16
That is not a 16G... It should spool at around 3 grand max.
Old 09-25-2004   #17
You should contact slowboy racing and call bullshit then. Seems laggy but they advertise it like that, so I wonder whats the deal?
CRAIG
Old 09-25-2004   #18
Eh thats too much work...
Just seems way to laggy to me.
Old 09-25-2004   #19
Couldn't it be possible the extra lag is from a combination of clipping and heavy porting? Maybe? :bounce:
Old 09-26-2004   #20
A 50 trim isn't that laggy.
