Old 09-24-2004   #1
stikx
Mr -
Big 16g
Fmic
550s
2g AWD
255 fuel pump
I was wondering at around what psi on the turbo will i be maxing the 550's
Old 09-24-2004   #2
Your not going to max them out on that setup ever. If you got a bigger turbo then you may think of getting bigger ones, but with a Big 16 550s will be fine for whatever that turbo has.
CRAIG
Old 09-24-2004   #3
illz
mine are at 105% duty cycle at 5800rpm 17psi in 3rd hmy:
Old 09-24-2004   #4
You must not have a 16G then.
CRAIG
Old 09-24-2004   #5
550s are good for about 400whp on base fuel pressure i'd say, and if you want more just raise the fuel pressure a bit
Old 09-24-2004   #6
Enes
Enes's Avatar
with my 50 trim, i was seeing somewhere around 99.8 % duty cycle and 34-35# air/min on 20psi ..
ocasionally it would jump to 105% duty.. so i just upgraded..
-E
Old 09-24-2004   #7
Just bump the fuel pressure. Yeah, craig is right, you won't max out 550's with a B16g. Once you get to a 20g, then you can if you get it cranked up.
