Old 10-07-2004   #1
:bowdown: We just got ours in at the dealership. :bowdown:
Let me introduce to you the Porsche Carrera GT :drool:
Here are some specs for you "need to know" guys. Copied from Porsche's info.
One of the most uncompromising vehicles ever created for the road, this latest generation of Porsche offers breathtaking performance in every respect.
From a standing start, it reaches 124 mph (200 km/h) in just 9.9 seconds en route to a top track speed of 205 mph (330 km/h).
To achieve that performance, we've applied a powerful V10 engine - developing 605 hp (SAE) - to an unladen weight of just 3,042 lbs (1,380 kg).
The main chassis structure - monocoque, windscreen surround and supplemental safety system - is made from carbon-fiber composites with a honeycomb core. The technologies involved are state-of-the-art in Formula One and offer exceptional flexural and torsional strength.
To the rear of the monocoque is a highly robust yet lightweight carbon-fiber structure which supports the engine and gearbox unit. This structure - known as the engine carrier - is bolted to the monocoque with which it forms the main stressed members on the car. The resulting chassis is extremely light, yet considerably stronger than the pressed metal shell on a conventional car.
The braking system features one of the latest advances in Porsche race engineering: the Porsche Ceramic Composite Brake (PCCB). This remarkable technology consists of a lightweight ceramic disc with involute cooling channels and a specially developed composite pad. Each of the front and rear discs has an impressive diameter of 14.96 inches (380-mm).
Cross-drilled and internally vented for optimum dispersal of moisture and heat, the finished PCCB disc offers an approximate 50% weight saving over conventional metal equivalents. Since all of that weight is entirely 'unsprung' - i.e., not supported by the car's suspension - the PCCB system delivers immediate benefits in terms of handling, agility and fuel economy.
Each disc is gripped by a powerful six-piston caliper with specially formulated composite pads.
Engine
No. of cylinders 10
Displacement 5.7 liters
Maximum power (SAE) 605 hp @ 8,000 rpm
Maximum torque 435 lb-ft @ 5,750 rpm
Maximum engine speed (revs) 8,400 rpm
Compression ratio 12.0 : 1
Transmission
Layout Rear-wheel drive
Gearbox Six-speed manual
Clutch Two-plate ceramic dry clutch (Porsche Ceramic Composite Clutch)
Limited-slip differential Multi-plate with locking under power and on overrun
Running Gear
Front suspension Double wishbones with inboard spring-and-damper units
Rear suspension Double wishbones with inboard spring-and-damper units
Steering Power-assisted rack-and-pinion steering
Brake Porsche Ceramic Composite Brake (PCCB) with 14.96 in (380-mm) ceramic discs internally vented and cross-drilled, six-piston monobloc aluminium fixed calipers front and rear
Traction control/ABS Traction control with ABD and ASR; ABS 5.7 (four-channel system)
Wheels Front: 19 x 9.5
Rear: 20 x 12.5
Tires Front: 265/35 ZR 19
Rear: 335/30 ZR 20
Weights
Unladen weight (DIN) 3,042 lbs (1,380 kg)
Performance
Top track speed 205 mph (330 km/h)
0-60 mph 3.8 secs
0-62 mph 3.9 secs
0-124 mph 9.9 secs
50-75 mph 4.0 secs (in fifth gear)
Quarter mile 11.4 secs
Fuel economy
Not available at time of publishing
Dimensions
Length 181.61 in (4,613 mm)
Width 75.63 in (1,921 mm)
Height 45.91 in (1,166 mm)
Wheelbase 107.48 in (2,730 mm)
Luggage compartment volume (VDA) 2.2 cu ft (63 liters)
72 liters non US markets
Tank capacity (refill volume) 24 US gallons (92 liters)
Engine
Water-cooled, naturally-aspirated V10 with 68-degree angle and four valve heads; engine mid-mounted with longitudinal layout
Specific output: 105.5 hp (SAE) per liter
Dry-sump lubrication with nine-fold oil pickup for optimum performance under all load conditions
Titanium connecting rods for smoother and more immediate engine response
VarioCamŽ variable valve control on intake camshafts
Electronic engine management (2x Motronic ME7.1.1)
Aluminium twin-flow resonance intake manifold
On-board diagnostics for monitoring the emission control system
Stereo lambda control
Transmission
Rear-wheel drive
Six-speed manual gearbox; transverse layout with transmission oil cooler
Limited-slip differential with locking under power and on overrun
Two-plate ceramic dry clutch: Porsche Ceramic Composite Clutch (PCCC)
Chassis
Double wishbones with pushrod actuated spring-and-damper units on front and rear axle
Forged magnesium wheels with high-speed Michelin tires (front: 19 x 9.5 with 265/35 ZR 19, rear: 20 x 12.5 with 335/30 ZR 20), central locking system and tire pressure monitoring
Body
Open-top two-seater layout with two-piece detachable hardtop in carbon fiber
Carbon-fiber chassis (consisting of monocoque, windscreen surround and supplemental safety system)
Carbon-fiber carrier for engine, gearbox and rear suspension with a honeycomb core
Engine carrier bolted to rear of monocoque as second fully stressed member
Frameless doors in carbon fiber with integrated side-impact protection
Front/rear lids, rear side panels and sill panels in carbon fiber
Front and rear aprons in plastic
Automatically extending rear wing
Underbody panelling with rear diffuser
Electrical systems
Remote central locking
Electric windows with door-seal protection
Power release lids
Electrically adjusted mirrors with internal heating
Single-blade windscreen wiper
Safety
Porsche Ceramic Composite Brake (PCCB) with 14.96 inches (380-mm) ceramic discs internally vented and cross-drilled, six-piston monobloc aluminium fixed calipers front and rear
Traction control with ABD and ASR; ABS 5.7 (four channel system)
Driver and passenger airbags, side airbags
Bi-xenon lighting system with halogen auxiliary lights and integrated headlight cleaning system
LED tail-light technology
Anti-theft protection system with infrared interior surveillance
Electronic engine immobilizer
Comfort
Bucket seats in leather with a carbon fiber and Kevlar shell
Center console with magnesium surround and raised gear lever
Aluminium gear lever with laminated wood gearshift knob
Five-piece travel set
Old 10-07-2004   #2
dylan
Drives: .
Where's it at and what does it take to test drive it?
... yeah right.
dylan is offline   Reply With Quote
Old 10-07-2004   #3
... yeah right.
Went straight from the transport truck to the shop for the check in inspection and then straight to the showroom floor. Never hit the street.
Old 10-07-2004   #4
vapour24
Guest
Tournaments Won: 6
Posts: n/a
oh my gosh!!! thats amazing!!~!
Old 10-07-2004   #5
Chris
Guest
Tournaments Won: 6
Posts: n/a
Have you seen the Top Gear episode with that car in it? Just plain jaw dropping. I think it lapped their test course the fastest (1:19 I think).
I can't wait for Bergstrom Porsche of Appleton to open. Shouldn't be too long before our store (Bergstrom Chevy/Caddy/Sabb of Appleton) starts getting Porsches for body work.
Old 10-07-2004   #6
Very nice, my desks all wet I didnt take your advice and put on a drool bib
Old 10-07-2004   #7
SuperSleeper
SuperSleeper's Avatar
Drives: 2012 Audi S4
Stats don't do this car justice. You have to hear it. Simply amazing. :3gears:
Old 10-07-2004   #8
Oh yeah, it sounds like a 2-stroke engine on steriods. Really likes to rev. Very responsive.
Old 10-07-2004   #9
1slowdsm
Now 1 second.....slower!
1slowdsm's Avatar
Drives: 1993 Talon AWD
:drool: ...that car is a beauty!......I'm speechless.
Old 10-07-2004   #10
JustROLLIN
SpunBearing
JustROLLIN's Avatar
I saw the thing tested on TV. Amazing.
Old 10-08-2004   #11
It started? Who got to move it!
He'll probably go nuts and steal it from the dealership.
Very awesome car!
Old 10-08-2004   #12
fievel
pictures of actual car in dealership please.
fievel is offline   Reply With Quote
Old 10-08-2004   #13
SlowWhite
Been there, done that.
SlowWhite's Avatar
exactly
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Best 1/4 - 11.7 on 93oct
Best 1/4 MPH - 120mph
Old 10-08-2004   #14
I'll get you some tomorrow, Saturday and post them.
Old 10-08-2004   #15
that's weaksauce, how about real pictures of a local car that was at carousel porsche?
Old 10-08-2004   #16
Old 10-09-2004   #17
wow thats sexy!!!!
Old 10-09-2004   #18
SuperSleeper
Gawd damn that's hot.
Old 10-09-2004   #19
IneedaGSX
Send a message via MSN to IneedaGSX
That is one hot car and I wonder what it would be like with TT setup.
Anyone know anyone with a GSX 2 Gen for sale with a manual?
IneedaGSX is offline   Reply With Quote
Old 10-09-2004   #20
SuperSleeper
Twin Turboing that car would ruin it. It's plenty fast the way it is. :toast:
