Old 10-09-2004   #1
stikx
Mr -
i got my j-pipe rewelded but i still get low vac at idle... the MBC is set at 17.5...vac at idle is near 10 psi or lower sometimes but when i rev it the vac will fall down to 17.5 then back up to 10 weird..i checked all couplers and reducers retightened everything....still low vac at idle anyone know whats wrong??? what to check???
oh yea and i keep hearing this hissing sound coming from near the injectors
Old 10-09-2004   #2
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
Remove the Injectors and replace the seals on the head side of the injectors.
Take her to the limit!
Old 10-09-2004   #3
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
you don't have aftermarket cams, do you? Do a boost leak test.
7/25/09
Old 10-09-2004   #4
Raptor
ConArtist
Raptor's Avatar
We did a boost leak test for him a few days ago and found enough leaks that they had to be fixed to find the rest, I would guess corey is right, the injector insulators can go bad and leak. If you want to bring it in again, we can check it to find out where they are now.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 10-09-2004   #5
Emcee gsxtc
Emcee gsxtc's Avatar
Throttle Body Gasket? I haed a massive leak on mine one night, everyone stared as I went buylike I had a semi turbo on my car.
Run your car not your mouth!
Pick Two: FAST CHEAP RELIABLE
Old 10-10-2004   #6
stikx
Mr -
i will try replacing the seals...and i need to get the lower IC pipe reweled too
