Old 10-12-2004   #1
x1genx
x1genx's Avatar
Drives: 90 1g awd
Send a message via AIM to x1genx
Does anyone know the specific size/thread of the nut that threads onto the alternator pin. Did anyone loose this and find it somewhere at their local hardware store. I obviously went to autozone and nothing they had fit it properly..either too big or just a little too tight to where it started compromising the thread. I am stuck in ohio untill i can fix the damn thing...the parts section of the dealership was closed all weekend untill tommorow morning so hopefully they have it, but i was just curious if anyone else has dealt with this and what they did to replace the nut..
thanks, im stuck and i want to go home
Erik.
x1genx is offline   Reply With Quote
Old 10-13-2004   #2
It is either 6mm by 1.00 pitch ( I believe that is standard. It is not a Fine or coarse thread.) or 8mm by 1.25 pitch. What size soccet fits it? I cannot remember. Spend 10 cents and get both. You may want to get a lock nut or atleast use a good lock washer so it doesn't happen again. It is not a odd size, it is just a common metric nut.
Old 10-13-2004   #3
x1genx
x1genx's Avatar
Drives: 90 1g awd
Thanks a ton.
I had just come back to reply that I found the size online finally.
It has a chart for all the stupid kids like me. I appreaciate it!!!
http://www.columbusdsm.com/resources/knowl...bolt_wizard.htm
