Old 10-31-2004   #1
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
no tach!
cannot seem to get my Tachometer to work. Everyother guage works!! We just got the engine in and running.. so it could be ne of the causes.. im looking to find the causes. And yes, the ground is connected to the intake manifold!
-the car is a 90 laser RST ( as you likely guessed) FWD turbo. EGr removed if that helps ne thing. 100% stock.
- Josh L.P.
Old 10-31-2004   #2
On the intake manifold stay (big bracket that bolts the head to the block on the back of the intake mani) is a little connector attached along with the knock sensor. That needs to be there and connected. I am not sure if that is what you are calling the "ground." It is a little connector. I posted a pic on here a while ago.
Old 10-31-2004   #3
http://www.dsmstyle.com/forums/showt...highlight=shit
Old 10-31-2004   #4
Pimpin Dsmstyle
Br0k3N
your talking about the engine side of the intake manifold? I have a little ground cable going from the fire wall to the intake manifold on the side facing the fire wall. What is the little connector thingy that is attatched to the EGR support on the back side of the block ?
- Josh L.P.
Old 10-31-2004   #5
No idea what it is for but I know you need it. There is a pic in the link I posted. It attaches to the stay with the knock sensor and the other EGR shit. If that is connected, check hte tach imput.
Old 10-31-2004   #6
Pimpin Dsmstyle
Br0k3N
its not connected. It is still on the bracket i removed. However, it doesnt lead to anything so i figured it was useless lol ( like the rest of the EGR shit). Do i just take it off the bracket and connect it to the lose wire and it doesnt lead to ne thing?
- Josh L.P.
Old 10-31-2004   #7
All I did was take it off the bracket and screw it into the firewall. It just has to be grounded to work. Anywhere should be fine. That should fix your problem.
Old 10-31-2004   #8
Pimpin Dsmstyle
Br0k3N
thanks man, ill try it in the AM. I need to talk to you about that car i think.. tehee. I keep accidentally calling your brother.
- Josh L.P.
