Old 11-01-2004   #1
2G headlight/bumper removal
How the f*** do you get the damn headlights off! There is 1 bolt that appears to be on the bottom side of the headlight that is holding it on, I cant seem to get to it! How the f*** am I supposed to take the bumper off if I can't remove the headlights?!
Old 11-01-2004   #2
There is a few plugs that are hard to get to and then yes bolt(s) on the bottom are a pain in the ass. It will not come out easily but if I remember you start with the sidemarker light and get that out and you can see back in there more and from there all I have to say is have fun.
Old 11-01-2004   #3
LightningGSX
Hellbound
Are you trying to remove the bumper or the headlights? The bumper will come off without removing the headlights.
-Nulli Secundus-
Old 11-01-2004   #4
I believe tuners has a write up for ya.
Old 11-01-2004   #5
Emcee gsxtc
Emcee gsxtc's Avatar
Just don't force anything, bolts in that area have a tendency to break off. Once the bumper is off, it is alot easier to remove the headlights.
Run your car not your mouth!
Pick Two: FAST CHEAP RELIABLE
Old 11-01-2004   #6
stikx
Mr -
dsmtuners.com has a write its in the tech section. yea there is a bolt behind the headlight, you have to get under the headlight to get to the bolt
Old 11-01-2004   #7
Enes
Enes's Avatar
remove the marker lights
raise up the car..
look on the two frame rails coming out to the front bumper..
there are 2 bolts in each rail..
remove those bolts 4 total
then remove all of the wheel well plastic... about 3 per side of the push pins.
slide the bumper out!
-E
