Old 11-27-2004   #1
SquackDiddy
Send a message via AIM to SquackDiddy Send a message via MSN to SquackDiddy
awd drifting?
have any of you drifted in your awd dsm? i guess you could say im not that into drag. and wondering if the dsm could drift because i think drifting is pretty cool. becuase i do want a awd dsm but if drifting wont work with it might get a 240sx. so can awd drifting be done?
I am on suspension because I refuse to type a decent sentence.
SquackDiddy is offline   Reply With Quote
Old 11-27-2004   #2
HondaKiller
HondaKiller's Avatar
I drift in the snow with my talon and mountaineer, but I don't push enough power to drift on dry pavement without the e-brake.
HondaKiller is offline   Reply With Quote
Old 11-27-2004   #3
SquackDiddy
i see. so pretty hard then.
Old 11-27-2004   #4
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
No.
That is all.
Old 11-27-2004   #5
SpicyOrange
What is the goal in drifting??? I don't understand it?
SpicyOrange is offline   Reply With Quote
Old 11-27-2004   #6
Yeah, you can definately drift an AWD. It won't usually step out quite as far as a RWD, but you can also pull it back in easier if you get too far gone. It is a little harder to get it to step out too because the power is split between the tires, but it is not terribly difficult.
Old 11-27-2004   #7
Yup, it can be done. We watched a AWD Skyline drifting out at SEMA, it made some hellacious noises but drifted real well. And I used to drift mine in the winter all the time, it's easier to control than a RWD.
Old 11-27-2004   #8
joem
Drives: 1991 Talon awd auto
Didnt you drift at the 1/4 mile track too.
joe
Old 11-27-2004   #9
520Talon
I tried drifting my Talon at an AARRF track day a couple of years ago. I ended up running off the track, couldn't get it to drift and then snapped my driveshaft going for an all wheel burnout. I did drift it a little yesterday when I took her out for the last time of the season.
All wheel Skylines have adjustable diffs to make them a much more RWD (90/10) car than a standard AWD. I saw it last year at SEMA and it was pretty cool.
Old 11-28-2004   #10
I have done some drifting going down on-ramps before. Nothing too huge, but stepping it out a couple of feet. You would need your suspension set up to do it, but it should work pretty good. A welded VC would help too.
Old 11-28-2004   #11
~300whp, a welded VC and some serious swaybars will do it like crazy:
-power: breaks the tires loose
-VC: puts more power to the rear wheels
-swaybars, upgraded in the front specifically will help the car tuck in when turning hard.
Old 11-28-2004   #12
SquackDiddy
i see. yeah i like a dsm better then a 240 anyways. where are drifting/autox events held in the midwest/minnesota? 300whp is easy with a dsm. would welding the vc be bad for reliabilaty? and the swaybars can be on.
Old 11-28-2004   #13
You might need to run 4 spare tires to keep all 4 broken loose on an AWD. DSMs run a 50/50 split with a stock or welded VC. People run welded VCs for dynoing or in hopes of saving the center diff from breaking. Running a welded VC, welded center diff or spool will be hard on your CV joints. They will probably start clicking after a few months.
Old 11-28-2004   #14
Actually, won't welding the VC also make the tires hop/chirp when turning when driving normally?
Old 11-28-2004   #15
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Very much so, I couldn't stand driving around with a welded VC in. The car would also slow down much faster in parking lot turns. I had to really get going faster than I wanted to just to keep going at slow speeds while turning.
I only use my welded VC when I want to dyno, otherwise it stays on my shelf.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 11-28-2004   #16
SquackDiddy
so what is a vc? : D
Old 11-28-2004   #17
It's the viscous coupler, it splits the power between the front and back wheels. I suggest going to VFAQ.com and checking out the 1000 answered questions and newbie FAQ. That will get you much more familiar with your car.
