Old 12-04-2004   #1
Khadgar
Can't Actually Wrench
Vacuum source
I think I narrowed down my MBC weirdness to the fact its on the same line as my bov.
I want to run another seperate line for my MBC and I was wondering where I could find it. Are the 3 ports on top of the TB the same as the ports on the manifold or do they act differently?
Old 12-04-2004   #2
SuperSleeper
SuperSleeper's Avatar
Drives: 2012 Audi S4
They all act the same directly off the TB. If you have an EGR blockoff, just use one of the sources on the TB and call it a day.
Old 12-04-2004   #4
Khadgar
I assumed the TB pressurized with the Intake manifold unless there is some wierd TB voodoo going on.
Old 12-04-2004   #5
dsm95gsxer
dsm95gsxer's Avatar
When I was looking for a vacuum/pressure source for my boost gauge I could only get vacuum off of the throttle body, so I ended up using the nipple for the fuel pressure regulator.
Old 12-04-2004   #6
Khadgar
That seems really weird, I don't see how you could get vacuum and not get boost, anyone else want to chime in?
Old 12-04-2004   #7
Sean485
Guest
Tournaments Won: 6
Posts: n/a
Not all the ports on the tb are vaccum, I know at least one of them is but some of them source on the turbo side of the tb plate (vs the plenum side) so thier pretty close to atmospheric at idle. The mbc being on the same line as the bov shouldn't matter as long as they are both getting a solid vaccum/boost source. Is the bov/mbc line connected to the port at the front of the intake plenum? If you really wanted a seperate source for everything you could run the bov off the port on the front of the plenum and then you could use the big fitting on the intake runners that is supposed to be for the pcv valve as a place for the mbc line assuming you have a catch can.
Old 12-05-2004   #8
Just run the mbc infront of your wastegate. Cut the line running from your bov line or the turbo compressor housing and put in the mbc before the wastegate.
Old 12-05-2004   #9
Khadgar
I don't really get what you are trying to say, right now I have it set up exactly like this.
http://taboospeedshop.com/Images/2G_emissions1.gif
Right now my boost controller doesn't really do any controlling it's very inconsistant, I've just recently read on other forums that having the BOV and the MBC going to the same nipple on the intake can sometimes cause this.
Also if you read the 1000AQs they say to not tap the line going to the FPR for your boostgauge, which goes against how Taboo does it, anyone know if this will cause problems with my FPR?
Old 12-05-2004   #10
Mine setup is just like Taboos and Ive never had a problem. Maybe try a different boost controller?
Old 12-05-2004   #11
Khadgar
I switched it out, I've always had this problem since I moved my BOV and needed a longer line from the T to the intake mani
Old 12-05-2004   #12
Khadgar
double post
Old 12-05-2004   #14
You can connect your boost gauge and mbc off the bov line if you want. I have connected my boost gauge off the FPR on a couple of instances. I have never had a problem. Maybe your boost controller is backwards. Did Josh install it for you...
Old 12-06-2004   #15
Raptor
ConArtist
Raptor's Avatar
hahahahaha, that is cruel John! All those nipples just confuse him
Actually, he has only done that once that i know of, damn human.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 12-06-2004   #16
Khadgar
It appears to work, wont know till it test it tomorrow. GL me.
Old 12-05-2004   #17
Khadgar
Right now I am looking at having my BOV off the TB and my MBC alone off the left intake nipple, and then my FPR and boost gauge off the right nipple. I'll post up whether this clears up my boost problems
Old 12-06-2004   #18
Khadgar
Anyone know which port on the TB will work, and any idea what size they are?
