Old 12-09-2004   #1
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
bad CAS??
Well I went to help a buddy pick up a truck over by Wausau, WI and on the way home my car started acting all weird. It was like the normal 6 bolt in a 2g misfire but it would not go away. Pulled over and shut the car down at a gas station for about 20 mins while we ate, then went out and she started just fine, drove it all the way back home (130miles) and when I pull into my buddies house the car completely dies, will not start back up for anything! Pulled it in the garage and checked for spark, none! Fuel is good, timing is perfectly all lined up, I dont know what happened. I had a problem awhile back where my CAS acked up and it ran like shit but it would actually start and have spark on 1st and 4th cylinder! Right now I dont have spark at all... I have 3 computers and I tested them all - nothing. Another thing that bothered me was while I was on the way home my stock tach was all fucked up! Even on the AFC II it was reading wierd (between 8000-2000rpms on the stock tach) like it was upside down but it would just constantly be jumping around, same thing on the AFC but there it would read from 3000-7000rpm when I was at 70mph with the cruise set. I have never had this happen to me before so I am lost in the dark. I havent had any problems with this motor yet, 5000 miles on it now, except for the CAS now has fucked up twice (thats what it apears to be!) I did a compression check, came out 175 across the board so it has me thinkin its the CAS. Someone please enlighten me. Thanks in advance!
Jake
Originally Posted by shoutbox
Old 12-09-2004   #2
Sean485
Guest
Tournaments Won: 6
Posts: n/a
Either CAS or possibly power transistor would be my guess as well.
