Old 12-10-2004   #1
Charged Air FPR
Has anyone run one of these? I know they're been fairly hard to get ahold of recently and see that Import Evolution has a few in stock so I was thinking about ordering one. I won't be using it for quite a while but was thinking about ordering one since they're available. The fact that they are a bolt-on FPR is the main reason why I was thinking about ordering one.
http://www.importevolution.com/produ...oducts_id=1432
Old 12-10-2004   #2
Well from what I've seen, I jumped to a conclusion way too early. Every recent piece of information I've been able to find suggests that the Charged Air FPR is the same thing as the Full Throttle Speed & Style FPR.
Old 12-10-2004   #3
They use a cheaper diaphram than the SX and Aeromotive FPR's. The diaphram does not like race gas and will begin to deteriorate when using it. It is really easy to use the Aeromotive setup. I would recommend that, along with most everyone on the board making over 400 whp.
Old 12-10-2004   #4
Or just don't get one at all!
Old 12-10-2004   #5
i don't think mo or cher either have them. and i'd say they make adequate power.
Old 12-10-2004   #6
So I guess I'm confused then since I repeatedly read about how a 255HP and even the 255LP will over run the stock FPR.
Old 12-10-2004   #7
It depends on the car. My 255HP over ran my stock FPR (tried 4 of them), so I had to get the Aeromotive. Some people run a 255HP just fine, it depends. A 255LP should be fine though, I would just get that and not worry about it for your setup.
Old 12-10-2004   #8
Originally Posted by JET
....A 255LP should be fine though, I would just get that and not worry about it for your setup.
Too late.
Old 12-10-2004   #9
Try trading with someone. I traded my denso 190 for a 255hp. Either that or SLS might swap if it is new. I am sure there would be a slight restocking fee though.
Old 12-10-2004   #10
The normal 255 and 255HP will have the same ability to overrun the stock FPR. If you have a good enough tuning device, it doesn't matter if it overruns it or not. Stock O2 sensor closed loop function should be able to compensate for any wackyness of overrun, if the your tune at idle/low throttle is close enough. I don't know what the big fuss over overruning the stock FPR is all about on the internet. Most of the people who complain about it probably have some other problem going on, overrun isn't going to cause knock, worst case your car runs a little rich. When you hack a MAS or run a 2G MAS on a 1G or running larger than stock injectors, you need to also compensate for that. Look at the SRT-4, they run 58psi all the time. Doesn't go up or down with vacuum or boost. It is a cheapskate factory system, but you can run a high base fuel pressure and make it work.
Old 12-11-2004   #11
My problem with overrunning the stock FPR was that I couldn't get the car to idle below 2k RPM. You will get the worst overrun at idle. I agree that running a high base fuel pressure would eliminate it, but don't you need an AFPR to do that? I suppose that would allow you to use one of the cheaper B&M ones.
Old 10-08-2005   #12
Re: Charged Air FPR
Anyone familiar with.....?
http://www.bellengineering.net/Pages/products_FPR.html
(Multi role model)
