Old 12-12-2004   #1
Pocketlogger and Maft Temp. integration?
Using the 1g MAS you can monitor temperature using the pocketlogger software. There must not be a temp. sensor on the GM MAS becuase it sits at 83 degrees and I believe that is what the ecu sees as well, even though it may be colder or warmer outside.
Is there anyway using a temperature sensor of some sort to wire into the stock harness the signal so I can display it on the logger and maybe have the ECU see the correct temp?
This would be nice to see IC temps as well as the correct temp for the ECU.
-LightningGSX can prolly answer this one but anyone else know? Hes probably in a body cast anyway, after his GSX-airplane stunt
TIA
