Old 12-19-2004   #1
BoostedGSX
Guest
Tournaments Won: 6
Posts: n/a
2G Auto AWD parts needed
I removed my transmission today from my '95 gsx auto. The bracket on the upper/backside...where it bolts to the bellhousing was cracked. So, thats the great 'CLANG' I heard when I was driving and I lost OD and 3rd gears. Also lost reverse. So anyway, we got the tranny out today, and all that. Now, I need this to put the other tranny back in...
Filter
Tranny Pan gasket
Transfer case gasket
2 CV seals
Half shaft seal
half shaft snap ring
(would like to get a shift kit too)
Thats all I need for the tranny. to go back up. I know I need ATF-3 fluid, but whats the best to use? And where can I get those things from?
Thanks for the help..
Old 12-20-2004   #2
LightningGSX
Hellbound
Re: 2G Auto AWD parts needed
I would imagine the mitsu dealer would carry it all
-Nulli Secundus-
Old 12-20-2004   #3
BoostedGSX
Guest
Tournaments Won: 6
Posts: n/a
Called today, they carry none of it.
Old 12-20-2004   #4
DSMPARTSGURU
Keeper of the lost toys!
where are you calling? would part numbers help?
tranny filter/gasket (MD997956)
cv shaft out put seals (MD707184/MD719710)
half shaft seal (MB526535)
snap ring for half shaft (MB526340)
Im not showing any gaskets for the t-case? I see 2 orings and 2 seal only...
chris
CHRIS
Wayzata Nissan
Old 01-07-2005   #5
jasonlee
Guest
Tournaments Won: 6
Posts: n/a
i have never seen a gasket on a t-case either... as far as those parts... when u called the mitsu dealer, did he ask for your vin #? if not, then he probably didnt even look them up... they need it to use there computer program from what i have been told...
every time i go, they ask for the vin before anything... plus it helps if they let u view the computer screen while they are looking it up.... sometimes they dont have a clue what they are looking for, and you will know it when u see it
j
