Old 01-07-2005   #1
Wizard50369
Send a message via AIM to Wizard50369 Send a message via MSN to Wizard50369 Send a message via Yahoo to Wizard50369
Hard starting problems
1990 Eagle Talon TSI 80,XXX miles
I was out racing around last week and drove home on an empty gas tank. When I tried to start it the next day it wouldn't, so I got some gas. Well 2 gallons of gas and 3 hours later I finally got it started. Drove around a little, turned it off, than drove to work. I let it sit again last night and today it wouldn't start (there's a full tank of gas in there).
The CEL is on and the weather recently got really cold. My question is where should I start checking things out. Did I mess up my fuel pump from running it dry? I hope so cause that would be an excuse for me to upgrade seeing how it's payday and all.
Ignorance Is Not A Virtue
Wizard50369 is offline   Reply With Quote
Old 01-07-2005   #2
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
Re: Hard starting problems
Ice in the fuel lines?
Take her to the limit!
Old 01-07-2005   #3
Wizard50369
Proably not, when I say cold i mean like 35 degrees F. LOL. Although I would love for it to freeze over or snow.
The car SOUNDS like its going to start or starts for a split second. Still can't get it though .
Old 01-07-2005   #4
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
How are your ECM caps? How is your fuel psi?
Old 01-08-2005   #5
Wizard50369
Don't know how my fuel PSI is, nor my ECM caps, but tomorrow morning I should go get some tools to test shit. Timing light, compression tester, vacuum tester, etc.
Old 01-08-2005   #6
Wizard50369
Ok so I got it started. I checked the relays, and some other stuff. They were ok. I checked for spark at each cylider and AFTER I did this it started right up. Any ideas on what this is?
Old 01-08-2005   #7
You probably had condensation in your fuel tank and you finally got it worked through the system.
Old 01-09-2005   #8
Wizard50369
Hopefully it's just something minor like that. I was hoping something fucked up so I had an excuse to buy new stuff. Oh well, I'll tell my gf that I "need" a fuel pump anyway
Old 01-25-2005   #9
Wizard50369
Fixed the problem, just a sensor in the thermostat housing that was unplugged
Old 01-26-2005   #10
santa
Boost Spike
santa's Avatar
lol running a bit rich?? haha I've accidently did that also. Good to know that you got it fixed up. I don't believe that you can get condensation in your fuel tank unless your below 1/4 tank and below freezing. I believe that fuel boils if I'm not mistaken, the flash point of gasoline is about -97F, meaning that it will still burn at 97 degrees below zero. Even the -97F mark is going to vary, based on the additives in the gas.
