Old 01-10-2005   #1
Iceman
Need EGT adaptor fitting
I lost my Autometer EGT adaptor that goes from the probe to the nut (welded in nut from QPR). Threads on both sides. I belive the one going into the exh man is 1/8 pipe thread. Anyone know where i can pick one up or do i need to order a whole knew autometer setup (some place SHOULD have what im lookin for).
Old 01-10-2005   #2
Re: Need EGT adaptor fitting
QPR should have a few of them unless they used all the ones I left there. I wouldn't know where they woudl be other than the bins but I know I left alot of those autometer fittings there. At least 2 or 3 sets with the little pressure fittings.
If your talking about that brass shit.
Old 01-10-2005   #3
Raptor
ConArtist
Raptor's Avatar
You better check in your tool box cracker, I don't have any in the bins. It is 1/8th NPT, if you don't find the fitting you need, I can make you one when I get out of the hospital, just let me know. It is a pretty simple thing to create, a drill, tap, and 1/8th pipe plug are all you need along with a little set screw.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 01-10-2005   #4
humm, they where probably used. No biggie. You had to bring up the $7000 paper weight huh. LOL
Old 01-11-2005   #5
Sean485
Guest
Tournaments Won: 6
Posts: n/a
Just lose the autometer probe and get a TRE probe (its male npt so wont need another fitting), the autometer probe is so slow it makes the gauge basically useless anyway
Old 01-11-2005   #6
I've used Autometer probes, Greddy Probes, and a TRE Probe. Never any noticable differance with them. And yes I do mean during operational movement.
Old 01-11-2005   #7
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Or just ditch the whole EGT thing altogether. My Autometer probe is acting up already after 4 months. Plus with a wideband like I have, I don't even pay attention to it except for the occasional time when I want to tune for cruising RPMs.
Anyways, if you got me a plug for the hole that would be in my manifold, I would give you the probe and part if you were interested. Mike did my EGT so whatever would be required to plug it back up.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 01-14-2005   #8
Iceman
I have heard good remarks on the TRE probe but we will see. Right now i have it pluged up with a 1/8 plug. I won't be back in MN for some time most likly but ill figure it out. Thanks.
