Old 11-25-2003   #1
92gsTEX
hey im new i know some of you but im just droppin to let every1 know i just got a 92 mitsu gsx not sure on what mods done to it yet but i plan on tons i just got it so i might need help gettin it up to par but im todd i work at wayzata texaco thats how i got the name gsTEX if wondering but if u got any suggest on what to do first hit me up always like to have info
92gsTEX is offline   Reply With Quote
Old 11-25-2003   #2
Welcome to the site! Post up some pics
Old 11-25-2003   #3
Punctuation is your friend.
Old 11-25-2003   #4
Black97civic
35mpg
tood that went to hopkins high school?
If so, its kemmy, whats goin on man? Decide to ditch the lude, or you keeping for a daily driver??
either way, good luck!!
Old 11-25-2003   #5
Jana
Mazda Bitch
Welcome! Yes, punctuation should become your friend.
I would recommend the basic mods first (boost controller, boost gauge, etc). Then it just depends how fast you want to be or how much hp you want to make.
Old 11-25-2003   #6
Iceman
Hey keemy its james, todds cusin. Yeah he got the GSX the other day and still has the lude. MODS on his car: boost gauge, TT (HKS), rust, and intake filter. Its white with white top i think? Pictures are doutful.
We know its a 3 bolt rear, but the engine where not sure on. We saw the picture of how the oil pan is different but was hard to tell, and cold.
http://www.dsmtuners.com/forums/showthread...&threadid=58328 <- link for foggy headlight fix.
You well never be faster than me!
Old 11-26-2003   #7
92gsTEX
yeah its todd from hopkins. the lude is gone james(iceman) kept smokin me so i decided to change it up. I'm sellin the lude to get parts for my gsx not sure what i want to go with but yeah iceman summed it up petty well with what it has done. thanks for the welcome and the tips. Also .,;'":/? ill work on what those buttons do on the keyboard. The pics will come soon enough also ill post them soon as i get them.
Old 11-26-2003   #8
Welcome to dsmstyle.
I use to work at that texaco.
Old 11-27-2003   #9
3 bolt rears come on 6 bolts (I am pretty sure atleast). You just didn't get the 6/4. Cannot launch past 6000 like me
Old 11-27-2003   #10
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
A 92 should have the 4 bolt rear end. Unless someone swapped it out. Having a 3 bolt rear end just means you can't launch it as hard as the 4 bolt rear due to snapping axles. No one that knows how to launch launches over 6k anyways.
'04 Honda Ricer: stock
Old 11-28-2003   #11
That is the whole point of the early 92's, you get a 4 bolt rear with a 6 bolt engine. You just need the big brakes then and you are set. I have three 6/4's :P
Old 11-28-2003   #12
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
92tsiawd84 got a newer looking 92 with a 7 bolt motor and a 4 bolt rear. Todd has the newer looking 92 (not pop up headlights).
7/25/09
Old 11-28-2003   #13
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
no 92 ever came with pop up headlights.
Old 02-05-2004   #14
1991-talon-fan
Guest
Tournaments Won: 6
Posts: n/a
Question people, What is so great about a 6 bolt engine and 4 bolt rear?
Old 02-05-2004   #15
The 6 bolt engine, out of '90-'99 DSM engines, is the one that has proven to be less prone to crankwalk. In the early part of '92 the blocks of the DSM went from a 6 bolt to 7 bolt. The 4 bolt rearend was substitued for the 3 bolt rearend in '92 and is a stronger rearend.
Old 02-05-2004   #16
6 bolt has a better block. Less prone to crankwalk and it has "big" (stronger) rods.
Old 02-05-2004   #17
Originally posted by 92tsiawd84+Feb 5 2004, 09:29 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (92tsiawd84 @ Feb 5 2004, 09:29 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-1991-talon-fan@Feb 5 2004, 12:43 AM
6 bolt has a better block. Less prone to crankwalk and it has "big" (stronger) rods. [/b][/quote]
I could be wrong but I believe all 1G shortblocks (6 or 7 bolt) came with the "big rods."
Old 02-05-2004   #18
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Nope. The 6 bolt rods are the Big Rods.
Old 02-05-2004   #19
Gotcha, my bad :smoker:
Old 02-05-2004   #20
GotBoost
Guest
Tournaments Won: 6
Posts: n/a
i got a 6 bolt with cower rods and weisco pistons, cams outta the cylcone engine, knife edged crankshaft, balence shaft removed, and engine ballanced... 14/b turbo of the cylcone engine.. ported housing, ported head, HKS ic piping, boost controler, front mount intercooler, ported exhaust manifold and ported intake manifold. 550cc fuel injectors 255wlbro fuel pump intake cone,act cluth, 3 inch down piping through the exhaust, no cat on it.....n1 tip... APEXi super AFC, took out the A/C and have 17 by 8 inch rims..
what should i be running?
5 speed TSI
1990
p.s. Super AFC isn't tuned, i was told to get a a turbo befor i tune it, and i'm looking to get cams, but i'm not sure how much of a differance there is between the cylcone cams and like street/drag cowers can u guys help me out?
sioux falls
Jake Long
