Old 01-20-2005   #1
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
Pinball Smash Up Champion!
New rallycross classes (kinda long)
The class designations will be SSR, SSF, SSA, RSR, RSF. RSA, RP2, RP4, RM2,
RM4. We may abbreviate the designations as SR, SF, SA, RR, RF, RA, P2, P4,
M2, M4. Basically, the groups would be Stock, Rally, Prepared, Modified.
The Stock and Rally groups have Front, Rear and All wheel drive classes
while the Prepared and Modified groups have 2 and 4 wheel drive.
Without further ado, here they are!
A. Rear Wheel Drive Street Stock 2 wheel drive-SSR
Front Wheel Drive Street Stock 2 wheel drive-SSF
All Wheel Drive Street Stock-SSA
In the Street Stock 2 and 4 wheel drive classes
1. All Cars must be equipped as came from the manufacturer,
with only factory-installed and port-installed option packages. Options
that were only part of a package must be present with the entire package.
Complete option packages may be installed after purchase of the vehicle.
2. Tire must be unmodified DOT approved. Snow tires are
legal. No studded tires are permitted. Tires may not interfere with any
parts of the car (fenders, fender liners, suspension, etc)
3. Wheel diameter, width, and offset are free.
4. The additions of protective equipment are allowed with
the following exceptions.
a. The modifications must only provide protection to the car
and/or occupants and provide no performance advantage.
b. Mudflaps and underbody chassis protection may only be
made of urethane and other plastic derivatives (i.e. no carbon-Kevlar)
c. Skidplates protecting suspension and drive train
components may only be made out of metal or plastic derivatives.
d. Driver restraints and roll cage may be added. Sunroofs
may be fixed shut.
e. Additional or replacement hood and trunk latches are
permitted. All latch systems must be secures.
5. Dress-up and convenience items which do not give a performance
advantage or reduce the weight of the car or weigh less than the standard
part they are replacing are allowed, i.e. shift knobs, pedal covers.
6. ABS and/or traction control systems may be electronically disabled but
not removed.
7. Vehicle lights may be replaced with alternate bulbs and housing.
Auxiliary lights may be added. The total number of lights shall not be less
than as standard.
B. Rally Street Rear Wheel Drive-RSR
Rally Street Front Wheel Drive-RSF
Rally Street All Wheel Drive-RSA
1. All Street Stock class modifications are allowed.
2. Sway bars and their mounting are free.
3. Brake pads and shoes are free. Rotors must remain stock.
Flexible rubber lines may be replaced by alternate lines, including braided
metal lines.
4. Exhaust systems from the most downstream catalytic converter
back are free with the following exceptions:
a. The exhaust must exit the body work.
b. The exhaust must exit to the rear of the
driver.
c. The exhaust must comply with the noise
restrictions.
5. The intake system upstream from the throttle body is free.
Under no circumstances may forced induction components be changed
(turbochargers, superchargers, intercoolers).
6. Short shift kits are allowed.
7. Front and/or rear strut tower bars are permitted.
8. Shocks are free but the shock/strut must mount to the
original mounting position using unmodified mounting points.
C. Rally Prepared Two Wheel Drive-RP2
Rally Prepared All Wheel Drive-RP4
1. All allowances from Rally Street are allowed.
2. Any tire is allowed.
3. Any spring of the same type (i.e. coil, leaf, etc.) as
standard is permitted. Length and rate are free. Threaded collars and
camber plates are allowed.
4. Electronic engine control may be modified using piggy-back
style computers, replacement or modified ECU's, or full stand-alone systems.
This specifically allows changes to fuel mapping, ignition timing. And boost
levels.
5. Brakes are free except no carbon brakes allowed.
6. Any replacement hood may be used.
7. Exhaust from the ports back is free with the following
exceptions:
b. The exhaust must exit to the rear of the driver.
c. The exhaust must comply with noise restrictions.
d. Downstream there must be at least one functioning catalytic
converter in the exhaust stream on cars originally equipped with catalytic
converters.
8. The clutch is free.
9. Seats are free but must be solidly mounted. All seats may be
removed or replaced.
10. Any car that is currently legal for stage rally competition in
other sanctioning bodies can run in its appropriate Rally Prepared class
regardless of whether it meets the Rally Prepared rules.
11. Glass, with the exception of the front windshield, may be replaced
with lexan or equivalent.
D. Open Two Wheel Drive-Rally Mod-RM2
Open All Wheel Drive-Rally Mod-RM4
1. All allowances from Rally Prepared are allowed.
2. Engines are free but must be internal combustion.
3. Drive train is free.
4. The suspension is free this allows changes to all
components and geometry.
5. Brake cylinders, number, type and dimensions, are free,
as are all lines.
6. Body work may be added or substituted with any material.
7. The interior may be completely stripped and/or replaced.
8. Additional chassis braces and seam-welding are
permitted.
9. All log booked race cars that meet entry requirements
are legal for the proper Open class.
10. The fuel system is free provided unleaded fuel is used.
