Old 01-30-2005   #1
remy
Guest
Tournaments Won: 6
Posts: n/a
afc question
Any idea how far the safc needs to be backed out for 780's on a 2g? The car sems to run best (but still really shitty) at -50. I cant get it set.
Thanks
Old 01-30-2005   #2
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Re: afc question
Just get DSMLink. That much air being taken out can't be good for keeping you in the appropriate timing maps.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 01-30-2005   #3
Re: afc question
You are probably going to need something like -42% on the low throttle settings. On high throttle, it will vary from one setup to another, but there is a good chance you might need to go farther then -50% depending on the turbo and boost you run. Why do you have such large injectors with only an AFC? 780cc injectors would support around 600whp, the closer you are to the injector size that you actually need, the better with an AFC. Your timing is going to be all out of wack with you having to go so far negative on the AFC.
Old 01-30-2005   #4
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Re: afc question
he is just using a 20g now and plans on using dsmlink but he needs to order it first.
7/25/09
Old 01-31-2005   #5
Re: afc question
My car was all f-ed up at -35 or so. I had the same size injectors but the 2g MAS leaned it out a bit. Then I found out I had an Eprom ecu. Eric fixed that problem.
