Old 02-03-2005   #1
Onefast99gsx
Question Question on cut divider - PTE Turbo
I have a PTE 50 trim that i'm putting on. I ordered it with the cut divider on the turbine housing. My question is regarding the 02 housing. Do i do any grinding to the divider that separates the 2 holes on the 02 housing or just leave it alone?
Thanks
Old 02-03-2005   #2
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Re: Question on cut divider - PTE Turbo
Ive been running mine with a 2g o2 housing with no creep. Im shure you will get better flow if you port it out some to match though.
11.35 @ 120mph
Old 02-03-2005   #3
Onefast99gsx
Thanks for the reply- I've already hogged the holes out themselves quite a bit. The outlet where the downpipe flange would connect to, is also hogged out. Perhaps that is good enough and i shouldn't dink with the divider on the 02 housing?
Other responses are welcomed here....
Thanks.
Old 02-03-2005   #4
You should be fine. What size of exhaust and DP are you using?
Old 02-04-2005   #5
Onefast99gsx
Hey Jet- it's 2.5" to the flex and 3" all the way back. Good to go then? No mods to the 02 housing divider?
Old 02-04-2005   #6
You should be fine. Every car is a little different, but that set shouldn't creep.
