Old 02-26-2005   #1
Onefast99gsx
Question Do you or have you ever ran a PTE SCM series turbo?
I have a PTE SCM-50 trim. It's .60 A/R comp housing. If you ran/run this turbo, what kind of clearance issues did you have with the water pipe? I'm just wondering if you have to dent it or did you use a thick spacer between the manifold and turbine housing. If you used a spacer, how thick?
Just trying to get a heads up on what i'm running into down the road as i get closer to mounting this thing.
Thanks.
PS- SCM series turbos bolt directly to the factory mitsu exhaust manifold.
