Old 12-02-2003   #1
Enes
Enes's Avatar
93 grand prix winter beater car ... 3.1l v6 automatic
Well, fixed the brakes, alternator and new tires.. etc etc.
now its time to fix the heating/cooling.. ..
The temp gauge works.. which is good.. it goes up to 220 and then back down to 190... then it sits there for a while and then slowly creaps up t 220 225 and then it sits there for a little bit and then backs down to 190 ...
one thing tho.. the fans never come on.. i checked all of the fuses.. i checked the relays... reseated them... changed them around.. can't imagine all 4 the same relays being bad.. i might just take and run new power to the fans and have a switch in the car that i can manually turn on and off
I am going to drain the whole coolant system and put new fresh coolant in it ... i don't know how old it is... and then i will most likely replace thermostat... as well..
