Old 03-29-2005   #1
1slowdsm
Now 1 second.....slower!
1slowdsm's Avatar
Drives: 1993 Talon AWD
resurfacing...
Does anyone know where I can get my flywheel resurfaced? I heard that Napa does it, but they charge $60 for it. I want to get it resurfaced my tomorrow so I can get my new clutch in by the next day. Oh yeah...does anyone know where I can get a list of torque specs for the flywheel, pressure plate, tranny, t-case and so on? I dont have a manual or anything.
Old 03-29-2005   #2
FORSFED
Re: resurfacing...
$35 at Motor Parts in So St Paul. But it may take a day or two...
Old 03-29-2005   #3
b00stingsx
Send a message via AIM to b00stingsx
Re: resurfacing...
$35 at Red Rooster, takes 30 minutes...
b00stingsx is offline   Reply With Quote
Old 03-29-2005   #4
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
Re: resurfacing...
Make sure they cut the right step Height for the clutch you are running.
Take her to the limit!
Old 03-29-2005   #5
Re: resurfacing...
You can swing by your local library and look in a DSM repair manual and everything will be in there as far as specs go.
Old 03-29-2005   #6
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
Exclamation Re: resurfacing...
Flywheel step height is probably the most important thing when it comes to the clutch working properly on a DSM and it's most often overlooked. If you install a new clutch always machine the flywheel to the clutch manufacturer's specifications. DO NOT ASSUME THAT JUST BECAUSE YOU BOUGHT A FLYWHEEL FROM A REPUTABLE SHOP THAT THE STEP HEIGHT IS CORRECT FOR THE CLUTCH YOU ARE USING. This varies with each clutch but most DSM mechanics agree that ***.608-.610"*** is the preferred step height when using most aftermarket pressure plates and discs. By machining the step height shallow it puts the spring plate fingers more on center. This in turn gives a more effective release and less pressure required to disengage the clutch. When you pick the flywheel up, have them measure the step height so you can be certain that they cut it to your spec and not what the "book" says.
Also do NOT use any thing other than a ACT clutch disc with an ACT pressure plate. ACT uses a HD marcel, the wavy metal that the friction material is riveted to, and it's designed to work with their pressure plates. Using a factory 2nd gen disc will cause the clutch to drag against the flywheel and prematurely wear out the synchros in your transmission when used with an ACT pressure plate. This is important and not exclusive to ACT so please consult with the manufacturer of your clutch when choosing to run a different clutch disc than the one supplied or designed for use with their pressure plate.
Do not reuse the flywheel if it has deep cracks on the surface. Have the machine shop inspect the flywheel with a Zyglo, Magnaflux or dye & powder for cracks after it has been machined. Flywheel explosions can injure passengers and destroy the car so don't abuse the clutch or use cracked flywheels. Do not use a factory disc with an aftermarket pressure plate. Most aftermarket clutch manufacturers have different disc thickness specifications and the use of a factory disc with their pressure plate will cause the clutch to drag or have a poor engagement threshold. If you have questions about the clutch it is best to contact the people you bought it from or the manufacturer.
Shim the clutch pivot ball with a 1.0-1.5mm washer. By by keeping the angles at 90* you get the most effective stroke of the throw-out bearing for any given amount of pedal movement.
Old 03-29-2005   #7
1slowdsm
1slowdsm's Avatar
Re: resurfacing...
Originally Posted by unreal808
7. Shim the clutch pivot ball with a 1.0-1.5mm washer. By by keeping the angles at 90* you get the most effective stroke of the throw-out bearing for any given amount of pedal movement.
What exactly does that mean? I've heard about adding a washer before putting the throw-out bearing in, but thats so the clutch doesnt have to reach the floor to disengage.
Yeah, I've got the Full ACT 2600 kit...so I should be good....just need the flywheel resurfaced and I should be good to put the clutch in.
Where is Red Rooster located? If it's close to where I live (st. paul, near downtown) then I'll go there. Otherwise I heard that Bumper-To-Bumper resurfaces flywheels also.
Old 03-29-2005   #8
Mighty Max
Guest
Tournaments Won: 6
Posts: n/a
Re: resurfacing...
I've seen this guy at work just sand his down and put a new disk in. He keeps telling me how fast his car is. Is he doing somthin wrong?
Old 03-29-2005   #9
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
Re: resurfacing...
Hi ken
Old 03-29-2005   #10
Re: resurfacing...
Yea he is doing something wrong... How does he know the disk is spec and even all the way around. Especially if he is just sanding areas around. That would make things aweful uneven.
Old 03-29-2005   #11
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
Re: resurfacing...
I also cross drilled my flywheel, than chucked it up in the brake lath and cut it so it shakes to off set to my balance shaft .
Old 03-29-2005   #12
1slowdsm
1slowdsm's Avatar
Re: resurfacing...
My cousin was also telling me to just sand the flywheel down a little and it should be fine and I was like..."Arumm...are you sure?" I dont want to take that risk and have to take out the clutch all over again within a couple of months....that'll just suck!
Nvm, I found out where Red Rooster is located. I'll give them a call tomorrow and see if they're better of Bumper-to-Bumper is better.
Still wanna know what Unreal meant up there about 5 replies ago if anyone knows what he meant.
Old 03-29-2005   #13
Re: resurfacing...
I also cross drilled my flywheel, than chucked it up in the brake lath and cut it so it shacks off set to my balance shaft .
Did you get it slotted too? I heard that helps release the gases that build up between the clutch disc and pressure plate.
Old 03-29-2005   #14
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
Re: resurfacing...
I would not sand the flywheel if you care about the clutch, I sanded the flywheel on the Talon AWD, but I put in a used clutch disk from my laser FWD.
