Old 04-10-2005   #1
Slimline fan Wiring hookup.
I bought a couple 9" slimline fans that are reversible to pull and push. They are supposed to come from the factory as pullers so I can mount them on the inside of the radiator and have them pull air through it...
I tested them out and they seem to blow away from the fan grille... meaning they would blow towards the front of the car installed. That would make it a pusher right?
I guess Im going to have to reverse them. My question deals with that. It says to reverse the blade, which I did. But what does reversing the polarity mean? I assume it just means make positive negative and negative positive. Basically switch + and - from what I had. I just dont want to try this before some clarifications and have the motors fry...
Also would it be safe to have both fans running of the existing wiring on my 1G awd? I would want to hook up both fans to run off the normal cooling fan wiring, (not the AC fan wiring). So instead of one stock fan there will be 2 9" fans that put out 3.5amps each. The specs on the fans are below:
(Each)
CFM Pull
1100-1250
CFM Push
1050-1400
Thanks in advance,
Peter
