Old 04-29-2005   #1
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
Ngk -11?
I asked for the bp.... ( i forgot the rest) but the ones we are SUPPOSED to run in the dsms. I put them in and all of that. For some reason, I think there was a dash 11 at the end. Now I am having spark issues. Could anyone give me some insite on this? Thanks.
- Josh L.P.
Old 04-29-2005   #2
Re: Ngk -11?
BPR7ES, unless your car is totaly stock you should run BPR6ES.
Old 04-29-2005   #3
Khadgar
Can't Actually Wrench
Re: Ngk -11?
Well if you have the wrong plugs, that's probably it....
Old 04-29-2005   #4
Re: Ngk -11?
They do make a BPR11ES I believe, and if you have them in your car it will most likely run like shit. I usually gauge it by boost with my cars, if you are running more than 16lbs then run the BPR7ES and anything under that run the BPR6ES. The BPR6ES are less prone to fouling as well.
CRAIG
Old 04-29-2005   #5
Re: Ngk -11?
No, he got some BPR6ES-11's. Did you check the gap before you put them in? The -11 just means the stock gap. I believe the -11's are .045" gap or something like that. They will need to be re-gapped to .028" or so. If you are running them stock the gap is way too big and will cause your spark issue.
Old 04-29-2005   #6
Re: Ngk -11?
JET is right, they are just a lot wider gap. Bring 'em down to .030" and you're good to go.
Old 04-30-2005   #7
Re: Ngk -11?
The plugs with -11 on the end mean a 1.1mm gap. You have to gap them way down to use them, next time just try to get the ones without -11 on the end, so that you don't have to bend the ground strap over so much.
Old 04-30-2005   #8
Pimpin Dsmstyle
Br0k3N
Re: Ngk -11?
i just bought the right ones. The fuckers at napa gave me the -11 instead of the regular ones and i dont have a gapper so i couldnt take car of it right away. The car is still missing all over. Mostly in the boost. I know the plug gap is part of it, but it was doing it with the other plugs ( good ones i had gapped at QPR and installed 100% properly). I guess it could be something fuel.. ideas would be cool.
- Josh L.P.
Old 04-30-2005   #9
Re: Ngk -11?
Spark plug wires.
Old 04-30-2005   #10
Pimpin Dsmstyle
Br0k3N
Re: Ngk -11?
Originally Posted by EclipseTurbo
Spark plug wires.
those were replaced.
- Josh L.P.
Old 04-30-2005   #11
Re: Ngk -11?
Coil
Igniton Transistor
Bad gas
Check plug gap again
Timing
CRAIG
Old 05-01-2005   #12
Re: Ngk -11?
No, even the correct plugs come gapped at .032". That is too much. Spring the $.79 and buy a plug gapper!
Old 05-01-2005   #13
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
Pinball Smash Up Champion!
Re: Ngk -11?
Come up and see me tomorrow. I'll let you borrow my gapper.
Old 05-02-2005   #14
Pimpin Dsmstyle
Br0k3N
Re: Ngk -11?
thanks anyways erik, i got it all figured out.
- Josh L.P.
