Old 05-03-2005   #1
AZT
Passing wired through the firewall.
Hey guys I was just wondering where are the spots in the firewall where you could pass wires through? Im going to be running 4gauge wire sooner or later, but tomarrows project is just normal sized wire. Anyone know?
Stupid me for forgetting my car, I drive A 91 mitsubishi Eclipse GS
AZT is offline   Reply With Quote
Old 05-03-2005   #2
Re: Passing wired through the firewall.
Well with an imaginary car make and model it is kinda hard to tell.
Old 05-03-2005   #3
Anduinlight
The Ghey Chef!
Anduinlight's Avatar
Drives: 2007 Toyota Tundra
yeah we need to know make model and year
98 Mitsubishi Eclipse RS - Gone
92 Eagle Talon TSi AWD - Parted out
10 Toyota Camry - DD
07 Toyota Tundra - For pretty much everything else
Anduinlight is offline   Reply With Quote
Old 05-03-2005   #4
The steering boot in the firewall works well on DSM's. For running a 4-gauge wire you'll probably need to drill a new hole though.
Old 05-04-2005   #5
LightningGSX
Hellbound
If this is a DSM, there are a shitload of places to drill through the firewall, both on the driver side and passenger side.BTW Don't be a stupid fuck and run the wire through bare metal either, use a grommet.
-Nulli Secundus-
Old 05-17-2005   #6
illusioneclipse
POST WHORE
Send a message via AIM to illusioneclipse
i used the steering boot on my car and i had to drill for the alarm.
illusioneclipse is offline   Reply With Quote
Old 05-17-2005   #7
Won't the shifter cable grommet work as well?
Old 05-17-2005   #8
Maybe but you cant really see it because its behind the console.. ts easier just to go right by the steering and master cylinder area because you can see it and have access to drill if the need be.
Old 05-17-2005   #9
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
i ran all my wires through the hole, right below the brake resevoir tank. Remove the 2 bolts holding it in place, and move it to the side..you'll have more room. Plus, it enters right above the driver's brake/gas pedal..
-A. Swift
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
