Old 05-16-2005   #1
dis_ill_usion
Guest
Tournaments Won: 6
Posts: n/a
Tourque Specs
I have a 1990 Eagle Talon TSi AWD, stock 4G63 motor, 2.0, turbo
I did a quick search but no luck, I need to know the tourque specs of the connecting rod nuts. I know someone is going to say "get a repair manual" or something of the sort, but I already have one and did some serious looking through it but can not find it. I know I am probably looking right by it, but I have tryed with no luck. Can anyone help me out here?
Old 05-16-2005   #2
Raptor
ConArtist
Raptor's Avatar
Re: Tourque Specs
14.5 + 90 degrees or 36-38 whichever you prefer, (on stock bolts/nuts that is).
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 05-16-2005   #3
dis_ill_usion
Guest
Tournaments Won: 6
Posts: n/a
Re: Tourque Specs
thank you greatly, that helps me so much
do you know where I can get some nuts and bolts other then the ARP package that I have found for $50? I only need one nut and that is it. After I get that nut the motor can go together and into the car finally.
Old 05-16-2005   #4
Onefast99gsx
Re: Tourque Specs
Contact Chris at Brookdale Mitsu. His screenname is DSMPARTSGURU on here. They ship too if you need it shipped to you. I'm in Wisconsin and when i order one day, it's here the next. Excellent service. He's on here quite a bit.
Old 05-16-2005   #5
Raptor
ConArtist
Raptor's Avatar
Re: Tourque Specs
You could stop by the shop, I have quite a few of them.
651-488-7774
Old 05-16-2005   #6
Re: Tourque Specs
Considering his location is stated as being International Falls I think he'll have a hard time going to Brookdale or QPR in a timely fashion.
Old 05-16-2005   #7
Raptor
ConArtist
Raptor's Avatar
Re: Tourque Specs
I didn't realize that till after the fact. Should be someone local that has a rod nut for him. I suppose if all else fails I could send one up there. If you have no other source, pm me your address and i will see what I can do to get to the post office in a reasonable time frame. Things are pretty crazy busy here these days.
651-488-7774
