Old 05-16-2005   #1
Onefast99gsx
Question HELP.... Injector fitting question/problem
I was putting my fuel system back on the car after putting the Magnus manifold finally on. I'm also putting PTE 780cc injectors on. I had all 3 bolts of the fuel rail torqued down to spec and i went to plug the wiring harness in and it won't fit. The injector is too tight up again the rail for the harness to slide down.
So i compared the PTE injector to the stock injector. Everything looked the same except the fuel inlet on the PTE was a bit longer. The stock injector has a rubber type grommet looking thing that goes on before the o-ring. Is that supposed to be moved over to the new PTE injectors? If so, i tried that but then it didn't seem like the injector was going far enough into the rail. I'm not referring to the o-rings. Those are fine. I'm also not referring to the grommets that go into the head either. This grommet i'm referring is just under the top o-ring. It butts up against the rail. If i move the grommet over to the new injectors, then it looks like i will have clearance it's just that the injector doesn't seem like it's in the rail too far.
Thanks much!!
