Old 06-15-2005   #1
TurboDomestics
TurboDomestics's Avatar
good idea for fuel setup?
http://www.stevetek.com/R-FuelSys.html
does this sound like a good procedure for making some fuel lines??
ill probably make some and acompany them with some 550 cc injectors and a 255 lph pump, and re-wire the pump, does this sound like a good fuel setup for a big 16g that will be at 15 psi, and then 20-25 psi when I get some hard IC pipes and maybe a FMIC or a better SMIC,
what do you guys think?
4G63 0, Charlie 3
Old 06-15-2005   #2
91nbtsi
Send a message via AIM to 91nbtsi Send a message via MSN to 91nbtsi
Re: good idea for fuel setup?
Not needed. Stock lines are good for about 550whp. I ran 10's on stock fuel system(minus pump and injectors obviously). Unless you want to spend the money just to have some cool looking fuel lines, you would be better off spending it elsewhere.
10.806@133.15--1991 Talon
91nbtsi is offline   Reply With Quote
Old 06-15-2005   #3
Yeah, definately don't bother. Spend the money on something useful.
Old 06-15-2005   #4
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Forget the bigger SMIC if you want to run 20-25 psi. Even the Supra SMIC still gets heat soaked pretty well at that boost level. I would just spend a little more and get a decent sized ebay core(find a good one though) and the appropriate pipes.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 06-15-2005   #5
Get a 190 fuel pump instead, you'll just run into extra problems with a 255 and its no where near needed for a big 16g.
Old 06-15-2005   #6
Speedfreak/Momin made 556whp with stock lines, stock filter, and stock fpr. TurboSpoolinInside/BuyMySC300/Cher made 617whp with stock lines, stock filter, and stock fpr. So, different lines are definately not needed with a 16G. And get a decent FMIC instead of big sidemount. The area that the sidemounts go on the car is not good for airflow with the tire spinning behind it and most big SMICs are really thick, which helps them flow more, but they don't have a big enough frontal area to discharge enough heat, so they heat soak very quickly.
Old 06-15-2005   #7
TurboDomestics
thanks guys!
thats what I was looking for!
4G63 0, Charlie 3
