Old 06-19-2005   #1
TGPilot
TGPilot's Avatar
Can anyone tell me what these lines are for?...PIC
While working on my oil leak issue I saw out of the corner of my eye two hard lines that have nothing going to it. Can anyone help me to identify them please??
Old 06-19-2005   #2
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: Can anyone tell me what these lines are for?...PIC
Vacuum lines for the emissions system. Not sure what they go to exactly. Possibly the EGR???
Originally Posted by shoutbox
Old 06-19-2005   #3
They just go from one side of the manifold to the other. You'll see the other side if you look right next to the coilpack on the driver's side.
Old 06-19-2005   #4
TGPilot
TGPilot's Avatar
I will look tomorrow...but are they just open on both ends or connected on the other to the manifold? Should they be capped if they are connected to the maniold or do I need to find a vacuum diagram and hook them up properly?
Old 06-19-2005   #5
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Do you have a boost leak or something? If not, don't worry about them. I would get rid of EGR and throw the whole bracket away. My guess is that the other side is off also.
7/25/09
Old 06-19-2005   #6
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
My car has the samething.
Its so you can hook up your PCV to your S-AFC to match CAS speed density crystal.J/K
But my car does really have the samething.
Take her to the limit!
Old 06-20-2005   #7
Wizard
I HAD the same thing, ditched all my emissions and threw it away. There are 4 metal tubes but only 2 are in use for most cars. Cali. cars use the other 2. They run to the EGR solenoid. It's up to you to ditch em or not.
Wiz
