Old 06-23-2005   #1
Onefast99gsx
Question Awww heck! I need some AWD launching advice.
admin- I didn't know where to put this because it does really fit any kind of tech category or pavement drag racing.
I feel stupid for asking but the car isn't going to the track until i can launch it. I'm too used to my old GST launching. I have a '99 GSX that i'm having troubles launching big time. I have my 2step studder box in dsmlink set for like 5600rpms. I tried just dumping it right off the floor and it bogs it terrible right down into the low 2k rpm range. I also tried letting clutch out some just to where she starts to grab and then dump it, same crap. Boost is at about 16psi for now because our 93oct. fuel sucks. 50trim turbo, etc. Ideally, you'd never want your rpms to drop below your studderbox level. I lose 2 seconds easily. I thought about 1 thing on the way home to add to this post. Over the winter i put in an entirely new clutch system, master, slave, clutch, SS line. My clutch disengages now probably 2+ inches off the floor. Last year when i first got the car i had problems with the clutch disengaging almost right off the floor, maybe 1/2". That's why i put all new in. Turns out the master was bad. Would you guys think that 2" would cause my launching problems? And where does your clutch disengage approx, off the floor ??
Old 06-24-2005   #2
Re: Awww heck! I need some AWD launching advice.
Mine is about 4-5" off the floor. I wouldn't ever drop it. I tried that a couple times back when I had a 16G and it would bog on me also when trying to launch at a reasonable RPM, I wasn't going to try it at 6200+ RPMs. Just learn how to quickly slip it.
Old 06-24-2005   #3
Honestly, I couldn't tell ya how I do it. It is just something you have to get a feel for. I have a stutterbox also and my pedal feels like 1 inch.
Old 06-24-2005   #4
I didn't have any trouble launching my talon before when I had the 20g. With the smallwer turbos, you can pretty much dump it, but with the bigger ones, you need to slip it more. Just keep on practicing the slipping and maybe try missing with the pedal hight more. My 2600 on my gst engages at stock hieght for me.
Old 06-24-2005   #5
Steeltwo
CompUSA Whore
Drives: 07 Civic Si, 06 IS 350 and I own a dsm
Send a message via ICQ to Steeltwo
i have a two step set at 5500.
here is how I launch with a 16g
This has to happen in about 1/4 of a second too, so you'll need practice.
gas all 75% of the way down. and slip the clutch about 1/3 the way. . As you push the gas to WOT, release the clutch at the same rate as you push down the gas. So basically alternate their location.
I keep my revs above 5 grand everytime and do not get any burnt clutch. The first 3-4 times I did it, I had too much clutch and did burn it a tad.
it is enough to keep r6's off my bumper till the middle of 2nd gear :-D
91 tsi awd
07 Civic Si
06 IS 350
Steeltwo is offline   Reply With Quote
Old 06-24-2005   #6
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Last season I had my stutter set at 6500, which was a bit high and I would spin pretty bad but still got 1.8 60 foots. But one thing you have to do is don't pull your foot up from the pedal, just move it to the left, that way you don't have the possiblity of subconsciously riding the pedal as it goes up. Just kick the kick panel is what I do. Then just work on fine tuning the point at where the stutter stops. Also how much boost are you building while at launch RPM? On my 16G I could build around 12psi which contributed to some of my wheel spin. Fortunately I had a two stage boost control which let me keep the boost low until I got out of the 60 foot, then I could turn it back to 22psi for the rest of the 1320.
Good luck.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 06-24-2005   #7
Onefast99gsx
Thanks guys for the great methods. I've printed and gonna try later if the pavements not wet here. I'm not sure on the boost during the studderbox. I'll have to check that later. It seems like when i had my boost up to 19psi, i had lesser of a problem on the launch. Also, when i first got the car and had the T25 yet, and the clutch was basically disengaging 1/2" off the floor, I never had this problem. It was basically like a light switch. You let it out 1/2" and it was full on. That's why i asked about where your points were. On regular street blacktop, i have NO wheelspin whatsoever. That will contribute to the rpms being pulled down.
I'm so used to the GST with it's wheelspin and wheelhop. It's hard to teach myself new tricks. I was hoping this was gonna be as easy as rev/dump but i can see it's more like rev/slip/dump. 19" wheels probably aren't helping me any either.
Old 06-24-2005   #8
Crazy
i think nitros would help put it to the floor and dump it then spray it. it should make up for the lag thats what i did on a costomers car once the car goss on the turbo he lets of the spray it is just for lonches but it is on a awd dodge stelth if that helps
Crazy is offline   Reply With Quote
Old 06-24-2005   #9
I always dumped from 6500rpm or higher and pulled high 1.7 60s on all seasons. But that was at an IA track with the torque monster T25
Old 06-24-2005   #10
Crazy
my costomer runs 1.2 60ft dutt he is not that good at shifting he runs 12.04 is his best at C.F.R
Old 06-24-2005   #11
Onefast99gsx
I'm think of upping the launch rpms and/or just playing with the antilag feature some. There is a mph setting in dsmlink for the studderbox. It's factory set at 7mph. I might bump that down to about 3mph.
Yeah, I never had problem with the T25 and launching because the boost was always there. On a laggy 50 trim(not too bad), it's like launching with a non turbo though.
Crazy- 1.2 60 fts????? That seems a bit low actually quite a bit low. Pro stock cars run 1.0-1.1. What's he got for a car?
Old 06-24-2005   #12
Crazy
dodge stelth with a 150shot for out of tha hole lonches and two 63trim turbo and a shit lood of axls lol every 3runs he brakes one the car is kapibul of 10s but he cant drive
Old 06-24-2005   #13
StealthGST
StealthGST's Avatar
Send a message via AIM to StealthGST Send a message via MSN to StealthGST
are you like 8 years old.... or drunk possibly?
1997 Converted 1995 Mitsubishi Eclipse GS-T w/ 6 bolt
StealthGST is offline   Reply With Quote
Old 06-24-2005   #14
Onefast99gsx
If i had to go through all that i'd been done with dsms long ago and switched to domestic RWD cars. Man! that just isn't worth it for running 10's. Dam! 2 63 trims! That car should do 9's.
Old 06-24-2005   #15
1.2 second 60 foot my ass. Show us a slip to prove it, or cut the BS.
Launch technique depends on a lot of things like power level, type of clutch, type of tires, track surface, etc. There's no magic formula for every car. One basic is slipping the clutch a bit, works for 9 out of 10 setups here. The rest of it is by feel.
I used to drop the clutch at 4500 rpms and spun my way to mostly 1.8's on shitty tires at slippery falls with about 390 whp. I'll be modifying my procedure quite a bit this year with alot more power and some sticky Nittos if I ever get them back from Ecoli.
Old 06-24-2005   #16
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
I could I get a link to some info on those 63 trim turbos? They sound really good.
Old 06-24-2005   #17
Onefast99gsx
Ok, i had a good night of about 6 or 7 launches in which 4 of them were what i thought really great. I changed the studderbox launch mph from 7 to 3mph. I think 7 was too much. I also bumped the studder from 5500 to 5850rpms. I also slipped it some. Basically, brought it off the floor about 1" just to the point where she started to grab good and then eased it out enough to still maintain rpms. One of those things where you just gotta do it and not think about it.
On the Gtech and on the dsmlink logs, I was running anywhere from a 5.08 to 5.23 0-60mph times. The 5.08, 5.12, 5.18 ones that i had felt the incredible. Basically gave me the disoriented butterfly feeling. Felt dam good. My boost is still kept low.
What do some of you run for 0-60mph times?
Old 06-25-2005   #18
that never happened.
1.2 reaction times, read the next line down on the timeslip.
Old 06-25-2005   #19
You should be running better 0-60s but you are on a g-tec. Believe I pulled 4.5s or so on a gtec on my old 16g and a stock clutch which was slipping(gtec also).
Old 06-25-2005   #20
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
I think it was more like 4 flat on the g tech not 4.5
7/25/09
