Old 06-28-2005   #1
DSMKPB
Spark Issues
I just swapped a 6 bolt into my 95 Talon and am having some problems getting it to fire up. I am thinking it has something to do with the signal going to to coils. What I have found is that when I put my multimeter with an inductive clamp on the spark plug wires is that cylinder #1 gets about 440 rpm #2 gets about 0rpm #3 gets 640rpm #4 gets 0rpm then i tried swaping the wires on the coil 1 with 4 and 2 with 3 the readings after that were #1 gets 0 #2 gets 640 #3 is 0 and #4 is 440. After this i tried swaping the coil with my 2g coil and the problem is exactly the same. Also when cranking there is no reading on the Tach, i really don't remember if there should be while cranking. If anyone has any ideas as to what could cause this, i would appreciate it.
1995 Eagle Talon TSi AWD - The Turtle - SOLD
2003 VW Jetta Wolfsburg 1.8t
DSMKPB is offline   Reply With Quote
