Old 07-02-2005   #1
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Issues
The car in question is a 95 gsx. It has normal fuel, intake and exhaust mods. Well James was driving my car and it drove fine (I was with him). He parked it. The next day I went to start it and it would fire and kill. The car is about to walk so I decided to wait and I disconnected the clutch safety switch.
I tried starting it agian without the clutch and it did the same. I did it once again and tried reving. With the throttle pressed, the car sat there for a second at 1000 and then finally reved up and dropped back down to 300 or so when I let off the gas and killed. Seems like it gained a big boost leak overnight or something. That is problem number one.
Since I had an Eprom ecu and a cable, I decieded I would pull out the SAFC and throw in DSMLink. I popped the covers and the wiring was a mess. The safc was connected with butt connectors not to mention other wiring. I soldered everything back together and get the laptop. I tried hooking it up and it cannot connect. I rechecked all the connections (ecu and laptop --> car) and everything seems fine. Sometimes I hear a clicking noise around the ecu area. I then have to turn the key off. The car cranks and everything like before but I now hear a random clicking sound sometimes.
Any ideas??? In summary, car ran fine and will no longer stay running. Clicking coming from around the ecu. Thanks in advance.
John (Carlos)
7/25/09
