Old 07-09-2005   #1
howslowcanyougo
Older than Dirt...
howslowcanyougo's Avatar
Drives: IX EVO MR/SE
MBC routing?
Before I cut over to this new FMIC I had a vacume hose from the bottom side of my MBC to a nipple on the j pipe, now with the new IC pipes there are no nipples, so where do I route this bottom MBC line to now?
TIA........
Let the madness begin...
Old 07-09-2005   #2
Onefast99gsx
Re: MBC routing?
You'll run to the wastegate and the other just "T" into a vacuum source. I just T'd off the one that goes to the BOV. If it's like a Hallman boost controller like mine, the line with the restrictor goes to the wastegate. It's that simple.
Old 07-10-2005   #3
Re: MBC routing?
Tapping into the BOV line is a good option when your compressor housing or outlet elbow doesn't have a fitting. Just buy a brass or plastic "T" of the correct size to match your vacuum hose at any hardware store.
Old 07-10-2005   #4
howslowcanyougo
Older than Dirt...
Re: MBC routing?
Thanks much Gents!
Old 07-10-2005   #5
Onefast99gsx
Re: MBC routing?
No problem. Good luck.
PS- It's a good idea to secure them with a zippy tie to keep them from coming off. That's what i use rather than clamps.
Old 07-10-2005   #6
Re: MBC routing?
I like to zip-tie every hose conection made whether its stock or modified as a precaution. Many potential problems and leaks can be avoided this way.
