Old 07-14-2005   #1
desolate
91 TSi AWD
desolate's Avatar
Drives: red 91 TSi AWD auto
oil leak
After the cam installation I'm getting oil all over my timing belt area. When I open the upper timing belt cover it all looks wet inside. The timing belt is even wet. The oil seems to have gotten on the outside of the lower timing cover also. I'm thinking it's the valve cover gasket or the cam seals. I didn't bother to change them since I thought they'd be fine. Where are the areas where the oil can leak from?
Old 07-14-2005   #2
Re: oil leak
You solved your own puzzle. Replace them bitches first.
Old 07-14-2005   #3
Re: oil leak
My bet would be cam seals, binding oil passage oil near the camshaft seal, or a pinched valve cover gasket.
So yeah, like allan said, good job you fixed it .
Old 07-15-2005   #4
desolate
91 TSi AWD
desolate's Avatar
Re: oil leak
Ok it was the valve cover gasket and the oil filter housing nut decided to back out loose also.
Old 07-15-2005   #5
Re: oil leak
Did you just tighten it? Many people use locktite on it to prevent it from happening again.
Also, very important. Don't just tighten it to 'whoa' its a good way to get oil and coolant to mix. That housing is somewhat fragile, and can be crushed easily by using the 'tight enough' torque method .
Old 07-16-2005   #6
desolate
91 TSi AWD
desolate's Avatar
Re: oil leak
Yeah I hear it's fragile. I tighten it down to specs (31lbs torque).
