Old 08-08-2005   #1
Anduinlight
The Ghey Chef!
Anduinlight's Avatar
Drives: 2007 Toyota Tundra
Unhappy might need a new tranny :(
Alright so I think this is where I should be posting this.
I was really hoping to hold of on having to do any type of tranny overhaul but maybe you guys can help me out with a more "cost effective" solution
I drive a 92 talon AWD I would assume the stock tranny with an act 2600 clutch, small 16g MBC set at 15lbs. I think other mods for info is not applicable
anyways, my problem is in normal driving (not boosting) my tranny seems to be biting gears as I shift (not a smooth trasition) when downshifting for say a corner, I generally shift into second but with the clutch all the way down it refuses to go into gear, unless I rev it up to maybe 2500prms. I also am not able to get into 2nd when under boost
Also when going from neutral to 1st (not moving at a stoplight/sign) it also will refuse to go into gear unless I coax it in somtimes it will still feel like it "bites" the gear.
and lastly my reverse gear will not go into gear without grinding, it does that grind...slowdown...intogear thing (I don't know how else to explain it :/
so Is my tranny/syncros/clutch toast, it there anything I can do? and if it is going to be a rebuild, how much does somthing like that cost, and would you guys reccomend anywhere specific?
I think I'm going to change out all the tranny fluid to see if maybe that will help, but its starting to be very difficult to drive my car
please help
thanks
Cole
98 Mitsubishi Eclipse RS - Gone
92 Eagle Talon TSi AWD - Parted out
10 Toyota Camry - DD
07 Toyota Tundra - For pretty much everything else
Anduinlight is offline   Reply With Quote
