Old 08-12-2005   #1
Tauni
Mazda-ing
Tauni's Avatar
Drives: 2013 Mazdaspeed3
K&N increase gas mileage?
If I were to get a K&N air filter, would my gas mileage increase per gallon? I don't care about the performance aspect, I just want to save some gas since I drive so much and the gas price is so high. Any information would be awesome! Thanks!
Old 08-12-2005   #2
Re: K&N increase gas mileage?
It will help slightly. Anything you can do to reduce pumping losses will increase gas mileage. An exhaust will help too.
Old 08-12-2005   #3
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Cleaning your stock filter would help a little also.
7/25/09
Old 08-12-2005   #4
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
stock filter can be replaced for like 10 dollars! Fuck cleaning it! lol. << LAZY
K&Ns are rechargable so in theory, they will last 1 million miles. You can follow the steps every so many thousand miles, and it will be as good as new.
- Josh L.P.
Old 08-13-2005   #5
Short answer: Yes.
Long answer: It will take an awful lot of driving to make up the price of the filter in gas alone, but the fact its cleanable and reusable will also save money in the long run. On the downside, the K&N will allow more dirt particles to enter your engine both causing a *slight* amount of extra wear plus causing your oil to become dirty and worn quicker. This is only an issue if you're interested in extended drain intervals, if you're changing oil at 3k miles this becomes a nonissue. On the topic of oil, follow Mitsu's oil change interval recomendations in the owner's manual, changing at 3k/3months is WAY overkill and wastefull unless you're really agressive with the car (which it doesn't sound like you are). A few extra PSI in your tires will help increase gas mileage, I generally run about 1-2 above the recomended in all my tires since I do a lot of highway driving and feel cornering performance improves with the stiffened sideway (the con will be a slightly rougher ride...but you'll also be extending tire life which is good).
Regarding stock paper filters, shaking them out every few thousand miles isn't a bad idea. This will get the larger surface pieces of dirt particles, bugs, etc. off allowing better airflow and extending the life a bit.
Old 08-13-2005   #6
Tauni
Mazda-ing
Tauni's Avatar
Now that I read this, I don't understand so well. You guys have all told me some different things.
Old 08-13-2005   #7
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
it can help but not really
7/25/09
Old 08-13-2005   #8
Tauni
Mazda-ing
Tauni's Avatar
OK thanks. That makes more sense.
Old 08-13-2005   #9
How does that make more sense? He agreed then disagreed within the same sentance.
A K&N is a good investment in the long-run since its the last air filter you'll ever buy for your car and will get you slightly better fuel economy while also gaining more power and response from your engine.
Old 08-13-2005   #10
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
Pinball Smash Up Champion!
Like Chris said, yes it will increase your mpg. But not so much that you will notice everytime you fill up. In the long run it will save you alot of gas. You might see 1-2 mpg difference at each fill up, but that adds up over time.
Also doing a good quality tuneup, keeping your tires inflated to the proper pressure and using good gas will all help increase your mpg.
All of these added together will make a dramatic difference if you are getting poor mpg. Keeping your engine healthy is the biggest key to getting good mileage.
I stand behind K&N filters also if for nothing else than it is cheaper in the long run then replacing your air filter at the recommended intervals.
Old 08-13-2005   #11
I saw a 3-4 mpg increase on my old mazda mx-6 after replacing the filter with a k&n and opening up the air box. I put a k&n in anna's lancer and saw 2-3 mpg increase, but the stock one was soooo dirty, after swapping in the k&n, I swear the car had 15 more horsepower!
Old 08-14-2005   #12
Tauni
Mazda-ing
Tauni's Avatar
Alright, thanks guys!!
Old 08-14-2005   #13
Pimpin Dsmstyle
Br0k3N
I told her to look into getting one... she found out today that she has one! haha. My bad!!
josh
- Josh L.P.
Old 08-14-2005   #14
Tauni
Mazda-ing
Tauni's Avatar
haha
Old 08-17-2005   #15
KcGsXrated
KcGsXrated's Avatar
Drives: 93 Talon Tsi
Send a message via AIM to KcGsXrated
You might consider not driving so much... Your car has better chances of running longer. Tiny T
~~DSK~~
Casey
93 Eagle talon Tsi fwd auto
KcGsXrated is offline   Reply With Quote
Old 08-18-2005   #16
Tauni
Mazda-ing
Tauni's Avatar
Ha, we all know that will never happen.
