Old 08-14-2005   #1
Reapping the Block
I'm gonna retap the head stud threads on the block (for ARPs). Should I use any lubricant? I was reading, and I read you can tap cast iron dry, or at least use air to blow away stuff (or suck it up).
Thanks, Kevin Swalchick
Old 08-15-2005   #2
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Re: Reapping the Block
I would use thread cutting oil when taping it and then make sure to blow the holes out before installing the headstuds. You might be fine without the oil, but I would use it.
7/25/09
Old 08-15-2005   #3
When retapping something it isn't necessary to use cutting fluid. Basically all you will be taking out is rust.
Old 08-15-2005   #4
thanks
