Old 08-22-2005   #1
GayRat
Guest
Tournaments Won: 6
Posts: n/a
K, I dont know whats wrong.
Ok, this is the problem...... i think i either have a oil leak or something else is wrong. when i let my car idle it does just fine until i rev it or take off, when i do that lots of white smoke comes out my exaust and from the engine (maybe my hole in my flange?). ok it usually only does this at a long stoplight or something like that so i think that the oil is burning.
Yea im not really sure whats wrong but if u could point me in a direction thad be sweet. i have a 90 talon tsi awd if that helps.
Old 08-22-2005   #2
dsm10sec
dsm10sec's Avatar
Send a message via AIM to dsm10sec
Re: K, I dont know whats wrong.
White smoke would be coolant.. Might be your headgasket.
dsm10sec is offline   Reply With Quote
Old 08-22-2005   #3
GayRat
Guest
Tournaments Won: 6
Posts: n/a
Ok another thing is that the smoke smells a lot like burning oil and also my oil level constantly gets low, like its dripping/leaking or something, but heres the thing, i have yet to see drips of anything anywhere i park.
Old 08-22-2005   #4
You either have a blown turbo, a bad head gasket or valve seals that are leaking severely.
Old 08-22-2005   #5
GayRat
Guest
Tournaments Won: 6
Posts: n/a
which should i check first?, im pretty sure my turbo works good.
Old 08-24-2005   #6
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
Well you could do your valve seals in car... OR.. You could take off the head, do your head gasket, install new valve seals ( or pay a machine shop), then redo your timing belt with all new pullies and tensioners and obviously a belt. OEM mitsu plz
- Josh L.P.
Old 08-25-2005   #7
Outlaw1
Resident Redneck
Outlaw1's Avatar
Pull your spark plugs and see if you have oil on them. Usually it will run like crap if even only one spark plug is oil fouled. If your plugs look normal, the turbo is taking a dump.
Old 09-08-2005   #8
rk4g63
Burp!
Cheapest way is to pull the spark plugs and check for fouling. If none are fouled, then check the turbo seals. Good luck - hope it isn't costly.
