Old 08-30-2005   #1
Enes
Enes's Avatar
head issues
LOL
I did a leakdown test last night and gave up.
Put #1 to TDC , hook up air/gauges, 100psi drops down to 12psi . i listen to air, its coming out of spark plug hole on cyl#2 WTF
i put it on #4 hook up leakdown tester, shows 89 on this one.
move #2 to TDC, hear air coming throu #1 shows 12psi on the gauge
check on #3, air coming out of #1 shows 12psi on gauge..
how are #1 and 2and 3 tied together? any possible way?
-e
Old 08-30-2005   #2
Re: head issues
It's all in your head.
Honestly, the only thing seperating the cylinders are the pistons and the head gasket.
Old 08-30-2005   #3
Re: head issues
You mean block and headgasket?
When you are doing a 'leak' test enes, pop off the radiator cap and listen for boiling. If you hear bubbling, you have a blown headgasket. They really shouldn't be pressurizing each other, unless you are pushing it past the rings into the crank case...
Old 08-30-2005   #4
Enes
Enes's Avatar
Re: head issues
Yeah i had the oil cap off, and i had the radiator cap off as well. no bubles there but that s probably because it can't build enough preassure in the cyl to get there. Since its all escaping into the cyl next to it.
If taking engine out didn't involve doing trany as well i'd so be taking the engine out of the bish right now. Or i should ask how hard is it to take engine out while keeping trany in there and then connecting it back together?
Old 08-30-2005   #5
Re: head issues
If you're pulling the motor, pull it w/ the tranny attatched. It'll save you some headaches.
Old 08-30-2005   #6
Enes
Enes's Avatar
Re: head issues
yeah i supose its easier, but is it worth it to take whole engine out to do headgasket?
Old 08-30-2005   #7
Re: head issues
No.
Old 08-30-2005   #8
Re: head issues
Just pull the head off. You should be able to have it off in a few hours, then you can see what the problem is.
Old 08-30-2005   #9
Onefast99gsx
Re: head issues
Enes- weren't you have troubles before with bad overheating? Head could be warped. Or am i thinking of someone else? I know you had some smoke troubles or something but i can't remember what the details were.
Old 08-30-2005   #10
Enes
Enes's Avatar
Re: head issues
it overheated a bit due to me leting it idle on turbo timer (no fans) without supervision.
i do have to mention the testing i did was on cold engine. will do it again tonight after i let it warm up
Old 08-30-2005   #11
Onefast99gsx
Re: head issues
Does it smoke white at all?
How about oil on the dipstick, is it milky looking?
Those cylinders shouldn't be associated with one another at all. Air would have to bypass one set of rings, go into the crankcase, travel up to another cylinder and bypass its rings. My guess is the headgasket is shot.
I used a stock headgasket, and i sprayed each side with copper spray when i redid my head. Been holding up fine. Are you using ARP's? What's the most boost you hit with your 50trim so far?
Old 08-30-2005   #12
Enes
Enes's Avatar
Re: head issues
ARP's, 24psi 111 octane.
oil is clean, coolant is clean
its probably blown between cylinders, even tho the car idles and runs just fine..
super weird.
-E
Old 08-30-2005   #13
Re: head issues
Why bother checking it when it is warm? If it is bad, it is bad. Let me know when you get the head pulled off. I have only seen DSM headgaskets blow from the cylinder to a coolant passage (except for my metal one last year that melted out the back side of the head).
Old 08-30-2005   #14
Outlaw1
Resident Redneck
Outlaw1's Avatar
Re: head issues
Did you TDC the cylinder right after the exaust valves closed or when the intake valves closed? If you try to pressure up the cylinder during overlap it will do what you are describing.
Old 08-30-2005   #15
Re: head issues
Are you sure you did the test on the compression stroke at TDC and not just at TDC?
Old 08-30-2005   #16
Enes
Enes's Avatar
Re: head issues
uhm... stupidity at its best... proven..
not sure, i just got it to TDC and did it. yaay RTFM
Old 08-30-2005   #17
Outlaw1
Resident Redneck
Outlaw1's Avatar
Re: head issues
Do you know how to check to see if you're on the compression stroke?
Old 08-30-2005   #18
Re: head issues
Hahah, oh man... Let's us know how that goes for you.
Old 08-30-2005   #19
Enes
Enes's Avatar
Re: head issues
please advise on how to check to see if i'm on compression stroke..
;p
Old 08-31-2005   #20
Enes
Enes's Avatar
Re: head issues
So how do i determine that Cyl1 is on compression stroke, ?
same should apply to #4 at the same time correct? or are they not at the same stage?
-E
