Old 10-03-2005   #1
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Do I need a new master/slave cylinder?
Ok, I have a 97 GSX and I installed a ACT 2600 clutch about a month ago and everything went fine. But recently there is a squeaking noise when I press the clutch pedal coming from somewhere in the engine bay right behind the clutch pedal and the firewall. It also feels like there is a strain on the clutch pedal along with the squeaking sound when I press it, like something is rubbing against something else? I don't know how to describe it. No fluids seem to be leaking, I check almost every other day to be sure. I tried doing the clutch pedal adjusting thing, not sure if I did it right, but that didn't seem to do anything except slightly reduce the distance the clutch pedal travels. Does anyone know if these are symptoms of a bad master/slave cylinder? Should I bleed the clutch again? Anyone have any ideas?
