Old 10-05-2005   #1
mitfastgsx05
Stripped Bolt?
I am finally taking off my turbo and replacing it with a 14b. Well we disconnected my downpipe and disconnects all the lines and we took out every bolt pretty much and i believe their is just one bolt left. we started to take everything off then we get to this bolt and it seems like it is stripped in the middle or something? It will unscrew a certain amount then it just stops and just spins? What would the best way to get this out? Can i just cut it and tap it out or how should i go about this.
thanks for all the help
mitfastgsx05 is offline   Reply With Quote
Old 10-05-2005   #2
Enes
Enes's Avatar
Re: Stripped Bolt?
please be more specific which bolt are you talking about
Old 10-05-2005   #3
GVR-4579
Re: Stripped Bolt?
you could try prying on the bolt head wile turning it, if there is room
Old 10-05-2005   #4
mitfastgsx05
Re: Stripped Bolt?
i believe its the top right of the 4 bolts on the manifold holding the turbo on.
Old 10-05-2005   #5
PSI2HI
Re: Stripped Bolt?
If your replacing the turbo take the whole thing off as a whole then just cut the bolt off outside the car.
Old 10-06-2005   #6
Re: Stripped Bolt?
Couldn't you use somethig with a cut off wheel, such as a dremel or a grinder?
