Old 10-12-2005   #1
TsiEagleTalon92
TsiEagleTalon92's Avatar
Drives: 2022 Hyundai Palisade
Interrior backlighting does not work.
I got done putting a radio in my cousin's car that I am borrowing and the interriors backlights do not work and I do not get any warning for having the lights on. I need some insight on what is wrong and how to fix it. Thanks.
They worked fine this morning and I checked all the fuses.
Old 10-12-2005   #2
TsiEagleTalon92
Re: Interrior backlighting does not work.
Also when I have the lights on I do not have tailights until I press the breake and I do not have reverse lights.. Please need some help badly.
Old 10-13-2005   #3
take out your wiring & double check it. look closely at anywires near what you were playing with & make sure you didn't break something or pull something loose.
Are you sure you checked all the fuses? Even the ones under the hood?
Old 10-13-2005   #4
TsiEagleTalon92
all that I know about there are 2 under the hood and one on the driver's side and they all lookd good even the elements. the wires I was playing with were all in a harness and it was a kookup for the stock radio I believe idk if that coulda tripped something or not. What I want to do is have somone from this site or something look at it for me until my cousin get back but everything looks to be ok.
Old 10-13-2005   #5
did you check the fusebox under the dash, near the clutch?
Old 10-13-2005   #6
Outlaw1
Resident Redneck
Outlaw1's Avatar
Ok, let's assume this is a 1G DSM. In the factory radio wiring harness there is a wire that runs to the dash/parking lights. If you did a ghetto splice install instead of buying a plug-in harness, I'd say you somehow got into that wire.
'07 Z06 Black/Black 2LZ
10.48 @ 136.86 w/1.65 60'
Old 10-13-2005   #7
TsiEagleTalon92
which wire is it that runs the dash/parking lights because that is in fact what is triggering it. I possibly have the power and ground in the wrong places and dont know which ones to go to. I don't have any more fuses so I want to be sure what it is before anything further happens.
Old 10-13-2005   #8
TsiEagleTalon92
Oh and do you guys know where a fuse or something would be so I get reverse lights? I'm pretty sure they worked before but don't now.
