Old 10-15-2005   #1
ECU Cap Leaking
Every now and my 1992 Eagle Talon Tsi AWD 5spd throws a Code 44: Ignition coil thingy. Today, I checked the coil, its perfect. I'm currently checking the power transistor, so far its bad (there is supposed to be no continuity in one spot, and there is!). Any ways, I pulled the ECU (non eprom sniff sniff) and I noticed a brownish haze coming from a big fat cap on the board. I cleaned it away with electronics cleaner and a q tip. What should I do, where should I go to get the caps replaced?
And also, could my leaking ECU caps cause the problem with my ignition system? Or make everything not work right? What happens when your ECU "goes bad"?
