Go Back   MitsuStyle > Hosted Support Forums > LSE Performance
Closed Thread
Old 10-18-2005   #1
ECU Cap Replacement.
Hey LSE,
I stopped by yesterday (10/17) with my ECU from my 1992 6-bolt AWD M/T DSM. You took a look at the underside of the board, and there was no damage. I got quoted 1/2 hour labor also I checked out Vfaqs, and I went to Axman (University Ave in St. Paul) and got three caps: 47 uF 50v, 100 uF 25v, and 22 uF 100v. I could not find any smaller voltage RADIAL caps for 22 mu fareds. It might not work, as the 100v is physically larger than to stock one, but the one right next to it is actually smaller in size. So it might just work out. I'm probably gonna drop the ECU and caps off at about noon tomorrow (10/19)
Kevin Swalchick
651 494 9779
sleepydsm is offline
Old 10-19-2005   #2
Re: ECU Cap Replacement.
thanks see you then.
niterydr is offline
Old 10-21-2005   #3
Is it done yet? I'd like to get it sometime about noon if possible. Thanks! I'll give ya a call today.
Old 10-21-2005   #4
Actually, due to an issue at the bank, I cannot pick up the ECU until Tuesday, Oct 25th. I appologize if that is any inconvience. Also, would you consider a direct trade for the ECU for my ported 14B that worked great while it was on my car? I was trying to sell it for $75, but no one has needed a 14B lately. If not, I will be there Tuesday to pick it up with cash in hand. Thanks!
Old 10-21-2005   #5
Kevin, that might work, bring the turbo by. I'll call when its done (probably in an hour or so from now).
niterydr is offline
Old 10-21-2005   #6
Alright, thanks.
Old 10-21-2005   #7
Going to work, won't be home until 8. Guess it will be Tuesday then...
Old 10-21-2005   #8
shoot, just called you, its done. I'll be here later tonight if you want to still pick it up. Just call the shop when you are off work to see if we are here.
niterydr is offline
Closed Thread
