Old 10-19-2005   #1
dumb_ricer
Hates Everything
Drives: Neon
Rather advanced questions on electrical theory!
Okay, so we all know how a ignition coil works. You have a primary winding and a secondary winding. The primary winding gets energized with a relatively high amperage and approximately 14volts, and then voltage is cut off, and the magnetic field caused by the current collapses causing current to jump over to the secondary coil, causing HUGE voltage and very low amperage. When this happens, it allows a spark to happen across the spark plug gap. But then you have to figure that the spark plug stays sparked for a given amount of time, and isnt just a tiny flash, otherwise you wouldn't get proper flame propogation acrouss the combustion chamber right? Still with me? good.
Alright, now here is my series of 2 questions.
1. We all know that the primary and secondary windings on the coil are seperate, and that source voltage cannot change. We also know that you cannot create energy, you can only change its form. So for the fact of keeping it simple, say you have 10volts and 10amps in a circuit, and volts times amps equals watts. So you have 100 watts of current flowing through the primary winding. Now you cut off the power, the magnetic field collapses, and in theory lets say you get .1amp at 1000 volts. Keep in mind these are not actual numbers. So you still have the 100amps of power, it has just changed state. Now today in class, I was told that there is NO drop in wattage and that 100 percent of the magnetic field collapsing is transferred over to the secondary winding. I cant see there being a 0 percent drop, and it being an EXACT 1:1 ratio between the primary and the secondary. Are my teachers full of shit and trying to avoid further confusion by saying it is an exact 1:1 ratio, or is there a "parasitic" loss in amperage due to it having to form and collapse a magnetic field, and transfer it all to another wire. It just doesnt make sense that it could possible be a exact 1:1 with no drop in wattage even though they are completely different circuits. What do you guys know/think?
2. Of course we know that the amount of gap and amount of resistence in the area between the electrode of the plug and the ground is going to determine the amount of voltage to complete the curcuit, but what then decides how long it is going to stay sparked? If the magnetic field on the primary collapses instantly, and electricity travels at the speed of light, and the magnetic field collapses instantly, transferring energy, then how can the spark plug possibly spark for any given amount of time, saying 2-3ms?
So what the hell is up and what am I not understanding? Or what are my teachers not understanding?
420A > LS1 > All Else
I > All else
